25th Feb 2016, 3:40 am | #1 |
Grundig 2x4 stereo, no rewind
I have a Grundig 2x4 stereo. I have had to repair 2 or 3 split edge connector plugs, and now the machine runs OK, plays OK, fast forward OK, picture search cue and rev OK, but when you select rewind it does nothing and then the tape light starts flashing. If you press tape button then the machine will function again, FF and playback OK, but still no rewind. Also, the modulator has low gain output. Has anyone had this, or do I need to find another modulator? Any ideas. Also, does anyone have a service manual in English, preferably.
Thanks, Simon.
Keep the soldering iron warm and never give up or you will kick yourself. BVWS MEMBER |
25th Feb 2016, 11:06 am | #2 |
Re: grundig 2x4 stereo no rewind
Hi. Which model is it? The 1600?
Fivos |
25th Feb 2016, 1:12 pm | #3 |
it just says 2x4 stereo on the label and below that order no 808 which i presume is model number
25th Feb 2016, 1:19 pm | #4 |
It's an 808, like the one in this picture.
25th Feb 2016, 3:12 pm | #5 |
This is the closest service manual I could find by looking on the picture. It is a mono model but the rest electronics should be the same.
http://freeservicemanuals.info/en/se...KTRISCHERTEIL/ Fivos |
26th Feb 2016, 3:06 pm | #6 |
Re: Grundig 2x4 stereo, no rewind
It is over thirty five years ago that I worked on these, one of the main problems were the contacts on the deck loading mechanism, if these are not clean making contact and in the correct position all sorts of strange things can happen. I do have a rather rough copy of the 2 x 4 super English manual, which I could if you wanted scan certain pages.
john |
26th Feb 2016, 3:12 pm | #7 |
Yes please, the mecha drive pcb at the back also the rf modulator.
thanks Simon
26th Feb 2016, 3:45 pm | #8 |
PM sent
John |
