Old 10th Feb 2016, 8:46 pm   #1
alm7rom
alm7rom's Avatar
Location: Al-Kharj near Riyadh, Kingdom of Saudi Arabia.
Question LG VCR Model-FL192. IC blowing.
Hi.
I have this VCR, no power because there are IC blowing.
Anyone have service manual or know the number?
Thanks.
ID:	119896   Click image for larger version
alm7rom is offline
Old 10th Feb 2016, 10:10 pm   #2
dj_fivos_sak
Default Re: LG VCR Model-FL192. IC blowing.
http://elektrotanya.com/lg_fl192w_sm.pdf/download.html
There you go.
Fivos
dj_fivos_sak is offline
Old 10th Feb 2016, 11:59 pm   #3
Red to black
Red to black's Avatar
Ouch! considering that is the EEPROM! according to the manual in above link thanks to Fivos , it is virtually certain that the machine is pretty much a write-off, there must be a VERY serious overvolt condition in the PSU !
Red to black is offline
Old 11th Feb 2016, 12:39 am   #4
ben
ben's Avatar
That's just what I thought when I saw that photo! Lightning damage?
VCRs of that last generation generally aren't worth repairing, and certainly not after having suffered that kind of damage.
Regards,
Ben.
ben is offline
Old 11th Feb 2016, 12:58 am   #5
Red to black
Hi ben,
the feed for the syscon is fed directly off the PSU before the fixed regulators, the regulation for that part being carried out by the psu itself by the looks of it, it looks like an over volt condition, either way the machine will most likely be a total write off.
Old 11th Feb 2016, 12:39 pm   #6
toshiba tony
toshiba tony's Avatar
Perhaps there is a translation difficulty here, I have nvm's fail but I have never seen one blown. This uses a chassis similar to the uk 888 range, I used to refurb 80 a day and had nvm failure but none were blown. All could be re-written to.
toshiba tony is offline
Old 11th Feb 2016, 2:58 pm   #7
Red to black
No translation problem in this case Tony The top of the eeprom has a hole blown out in the photo , to do that it will have almost certainly blown the μprocessor as well as anything else connected to that supply line.
To be honest I am a bit surprised that there is not more damage visible in the photograph.
I know where you were coming from with the phrase "blown eeprom" though
Old 11th Feb 2016, 3:24 pm   #8
dj_fivos_sak
As ben said, these newer 2000ish VCRs aren't very much worth repairing. Well-made VCRs were those built until the early 90s. My newest VCR is Panasonic FS200 G-deck from 1992 and I simply love this machine!
Old 11th Feb 2016, 3:46 pm   #9
toshiba tony
Sorry, hadn't seen the photo.
Old 11th Feb 2016, 3:55 pm   #10
Red to black
I thought that must have been the case Tony.
Old 11th Feb 2016, 6:36 pm   #11
Welsh Anorak
Welsh Anorak's Avatar
Re post #6 - that's dedication for you!
Welsh Anorak is offline
Old 12th Feb 2016, 11:43 am   #12
SteveCG
Perhaps the reason for attempting to repair the VCR is its multi-standard capabilities?
I was told that multi-standard VCRs abounded at one time in the countries bordering the Arabian Gulf.
SteveCG is offline
Old 13th Feb 2016, 12:49 am   #13
alm7rom
alm7rom's Avatar
Thanks to all
i will see if i found this part
alm7rom is offline
Old 13th Feb 2016, 1:17 am   #14
ben
ben's Avatar
It is a waste of time and money finding and replacing that eeprom IC (which presumably is preprogrammed to that model/series of VCR) until you have discovered and solved what caused its demise. And checked the rest of the machine is undamaged (which is unlikely).
Regards,
Ben.
ben is offline
Old 13th Feb 2016, 9:00 pm   #15
alm7rom
alm7rom's Avatar
Thanks
alm7rom is offline
Old 14th Feb 2016, 1:25 am   #16
Michael Maurice
Michael Maurice's Avatar
Before you go any further, Remove the main board and look at the processor and the print on the board itself, you may well find some burn marks around the processor and other parts of the board.
As others have said, with this kiund of damage, its virtually unrepairable and certainly uneconomic.
Forum Moderator
Michael Maurice is offline
