Old 14th Jan 2021, 1:48 pm   #1
woodchips
Default Sullivan 6666 milliohmmeter
Just had a need to use this, after about 6 years from the search results!
No go, meter just deflects to the right, no knob twiddling brings it to the left. Shorting the Kelvin probe solder connections inside the front panel does nothing.
Has anyone turned up any servicing info please? Got lots of bits inside, it worked years ago so can't be too serious, just which bit to change? Been stored inside as well so damp can't have got to it.
Thanks
woodchips is offline
Old 16th Jan 2021, 11:58 am   #2
John_BS
John_BS's Avatar
Default Re: Sullivan 6666 milliohmmeter
Duncan Research will sell you a manual?
http://www.benduncanresearch.com/manuals.htm#az
John_BS is offline
