9th Dec 2010, 11:21 am | #1 |
What to use - to remove Evostik
What can get this stuff off of wood? Apart from physically 'picking' it off, is there anything that will get it to dissolve?
SEAN
There are only 10 types of people, those who understand the binary system, and those who don't. |
9th Dec 2010, 12:00 pm | #2 |
Re: What to use - to remove Evo Stick
Cellulose thinners, acetone, MEK, in fact almost any proper smelly solvent. Don't use nail varnish remover it has oils in it and will stain the wood. Pop round to your local spray shop and scrounge 1/2 a pint (bring your own jar).
9th Dec 2010, 12:14 pm | #3 |
Many thanks
SEAN
9th Dec 2010, 12:24 pm | #4 |
How about their own product, I use it all the time when cleaning up unwanted evostick glue residue and for cleaning gunky wiring in TVs it's the best. I have cans of the stuff stored as it is so good. B&Q stock it.
Chris Last edited by oldticktock; 9th Dec 2010 at 12:40 pm. |
9th Dec 2010, 6:14 pm | #6 |
Re: What to use - to remove Evostik
Thats the same stuff Mike, but in the old tin and the old formula.
9th Dec 2010, 6:24 pm | #7 |
Confession: I have - when pushed - known myself to use petrol.
But I would not recommend this to anyone else, for reasons of personal safety and any possible unwanted consequent damage to the glued material(s). Al. [Skywave] |
9th Dec 2010, 10:57 pm | #9 |
I too use petrol for quite a lot of these type of applications. It will dissolve most adhesive type things including silicon. It very quickly removed the white adhesive deposit left behind by too long adhered duct tape. However, due deference must be paid to its heavy, highly inflammable vapour. I never use it indoors and always thoroughly 'air' the item it's been used on before taking it back into an enclosed space (house, garage). It will remove tar from car paintwork as well.
HTH TimR
All those moments will be lost in time, like tears in rain. |
10th Dec 2010, 2:09 am | #10 |
Toluene is magic.
It is the same solvent that is used in the glue. It is highly flammable and the vapour is heavier than air so it is best applied outdoors where no boiler pilot lights can ignite the vapour ! |
10th Dec 2010, 2:00 pm | #11 |
I too often use cellulose thinner or petrol - but not motor spirit as it stains! Always use lighter fuel - albeit a 'tad' more expensive - but then our hobbies are expensive and deserve the best!
Barry |
11th Dec 2010, 2:48 pm | #12 |
Will cellulose thinners remove old, set-hard Evostik without damaging Bakelite? I have a Bakelite cased radio that has been botched back together with this adhesive in an unsuccessful repair attempt by a previous owner.
11th Dec 2010, 3:26 pm | #13 |
More than likely not, rather depends on what is in it, Methyl Chloride (paint stripper) will after a while but is not usually in thinners, try a bit on the inside first.
11th Dec 2010, 4:04 pm | #14 |
Paint stripper is Methylene Chloride aka Dichloromethane.
Alan |
12th Dec 2010, 11:38 am | #15 |
It is extremely unlikely that lighter fuel will attack Bakelite, thermosetting plastic pheonolic resin, as it evaporates far too quickly!
Acetones and methly chlorides etc dissolve plastic to form a 'welded' bond when mending plastics. Barry |
