27th Oct 2009, 12:07 pm | #1 |
Removing old Sellotape deposits from plastic surfaces
I've recently turned my attention to the Sony ISC-5900W I acquired in a sorry state from Freecycle a year ago.
The plastic around the securing bolts has sheared off, and the back has been held in place by a mixture of clear Sellotape and brown sticky packing tape. This has obviously been in place for many years, and the adhesive has hardened into a disgusting mess. I have managed to clean off some of the deposits, but the really hard gunge is proving impossible to shift. I've tried white spirit, lighter fluid and meths. The gunge may have bonded to the plastic in some way, and I obviously don't want to damage the plastic further. Does anybody have any suggestions? I'm not hopeful about this, and the objective is to return the radio to everyday use rather than achieve a high quality cosmetic restoration, but I'd like to do the best job I can within reason. It's a pity the radio has been so badly abused in the past, as it works well electrically despite all the mechanical damage. Paul |
27th Oct 2009, 12:20 pm | #2 |
Re: Removing old Sellotape deposits from plastic surfaces
Maybe heat with a hairdryer to soften, then try the solvents again. And what about WD40?
Good luck, Nick. |
27th Oct 2009, 12:21 pm | #3 |
Try something a bit more abrasive, one of the supermarket cream cleaners, the "chalk" type.
27th Oct 2009, 12:23 pm | #4 |
Lighter fluid always seems to work for me so I guess you're right about some kind of chemical reaction. Perhaps soak it in lighter fluid for a while if it's really hard and crusty. Shouldn't damage the plastic.
Otherwise you're down to mechanical methods such as T-cut or even light sanding followed by polishing. |
27th Oct 2009, 12:23 pm | #5 |
try scraping it off with an old credit card or the like, it sometimes works
27th Oct 2009, 12:30 pm | #6 |
Maybe worth trying metal polish, I've found Brasso wadding to be very good at removing the residue from sticky labels, so I guess it would work on sellotape gum as well.
PS I like the look of those radios, I shall have to try and find one. |
27th Oct 2009, 12:40 pm | #7 |
I use Zylol/Zylene for stubborn cases,
Jim |
27th Oct 2009, 12:41 pm | #8 |
There is a label removal spray available from places like CPC, RS and so on, care needed to make sure it doesn't go on certain plastics and legends. But it does work, I have used it.
And like Nick suggests, try WD40 as well. Geof |
27th Oct 2009, 12:44 pm | #9 |
I too use Servisol label remover or petrol (Lighter fuel). As Geof says, be careful with the former though. I used some only the other day to shift a stubborn label from a video cassette - which melted.
27th Oct 2009, 12:49 pm | #10 |
Hi sorry I don't know the name of it, which is not a lot of help I know, but the fluid that is used to remove elastoplast type plasters seem to de solve quite a few adhesive left overs.
Cheers. Geoff. |
27th Oct 2009, 12:53 pm | #11 |
Try using one of the citrus based label removers, these contain Limonene (extracted from orange peel as a by-product) and are very effective. We use the Ambersil label remover spray at work, it is obtainable from Maplins on-line. Alternatively, Servisol label remover is available in Maplin stores.
Neil
27th Oct 2009, 1:19 pm | #12 |
also it may be worth mentioning that all solvents so far are non polar types, try a Polar solvent instead, window cleaner may work.
27th Oct 2009, 1:25 pm | #13 |
Good point, Geoff and Neil. We use "orange solvent" at work for removing set cement from instruments before sterilisation. Let me know if you want a little bit to try.
Nick. |
27th Oct 2009, 2:00 pm | #14 |
I have had success using 'Natural Blue' cleaner (not sure if this is still available or not.......) otherwise WD40, Toluene or Chloroform work remarkably well for sticky tape or label deposits. Although Servisol label remover is good, i would avoid it for that sort of plastic, particularly if any got onto the transparent plastic dial 'glass' - i assure you the results are not pretty!
27th Oct 2009, 2:09 pm | #15 |
Thanks for all suggestions so far.
I should make clear that the problem deposits aren't sticky or tacky in any way - white spirit removed sticky deposits without problems as I'd expect. These are very hard and impossible to remove with, say, a fingernail, and leaving them wetted with white spirit for 10 minutes didn't seem to soften them at all. I'll try WD40, though I'm doubtful that this will be more effective than white spirit as that is WD40's main cleansing component. I'll also try some T-Cut though this can't be used in all locations because of printed text on the plastic. Paul |
27th Oct 2009, 3:27 pm | #16 |
WD40 didn't do much, as I suspected would be the case.
T-Cut did improve things a lot - it got some of the gunge off, and polished the surface of what remains thus making it less noticeable. Hard work though There does seem to have been some sort of reaction between the adhesive and the plastic. I don't know the history of the radio, but being a high performance SW set it may have spent long periods in exotic locations with lots of heat, sunlight and humidity. It's certainly led a hard life. Paul |
27th Oct 2009, 3:27 pm | #17 |
These sound very similar to the "crystallised" deposits left by masking tape with which I was recently faced. In the end I only succeeded by mixing a good deal of "elbow grease" with (if remember correctly) WD40.
27th Oct 2009, 6:36 pm | #18 |
definately try some of the citrus based glue remover, I have some somewhere, its from Lakeland, and is called 'sticky stuff remover'. as a kid I had some old road works lights, and I stuck one to the window above my bedroom door with that nasty brown tape!! about 12 years later the remains of the tape had gone hard, so I used this stuff on it, and it came off! took a bit of doing, but it worked. used it on all kinds of things since then and its always shifted stuff. regards, Lloyd. |
27th Oct 2009, 8:47 pm | #19 | |
27th Oct 2009, 9:31 pm | #20 |
Hi Paul
If, as you say, a chemical reaction has taken place I think it is unlikely that a solvent will work too well. The polarity of the solvent was mentioned in a previous post. If this material would dissolve in a polar solvent then it would probably dissolve in water. I expect you have tried water without success. I suspect that the original gum used on this tape would have dissolved in IPA. If some of the gum remains unreacted you might be able to remove it with IPA and this in turn might help to loosen the deposits formed by any reaction that has taken place. The modern name for IPA is propan-2-ol. I think it might now be sold under this name. Good luck, Ken |
