Old 19th Jul 2007, 8:33 am   #21
Mike Phelan
Mike Phelan's Avatar
Default Re: Smelly danish oil??
Originally Posted by chipp1968 View Post
Contains tounge oil apparently. I didnt think you can mix the two
Tounge? Tung oil?
I use a water-based varnish (but not on radios). That is also milky looking until it dries and has a flammability notice on it, so must contain some oil-based stuff and some sort of emulsifier.
Any of the lighter alcohols will also mix with both water and oils. Meths and IPA, for example.
Originally Posted by PaulR View Post
I used Rustin's Danish oil on the inside of a clock case about four years ago and I can still smell it when I open it for winding. To me it smells quite pleasant, though.
Must try that, Paul.
I suppose that the the smell of Danish Oil, or anything else, will be objectionable to some, and not to others.
Mike.
Mike Phelan is offline
Old 19th Jul 2007, 8:55 pm   #22
PaulR
PaulR's Avatar
At the risk of going O/T here is a photo of the clock. I applied several coats of Danish oil and cut it back with Brasso. It was in very poor condition before I started. It also still smells of oil if you sniff it closely.
Paul
Name:	Slate clock.jpg
PaulR is offline
Old 20th Jul 2007, 12:19 am   #23
chipp1968
chipp1968's Avatar
Looks good , i have my grandparents one , its a little dull but doesnt respond to polishing .From the picture it looks well worth doing . I asume it must soak into the slate ?
chipp1968 is offline
