Old 4th May 2007, 8:19 am   #1
David G4EBT
David G4EBT's Avatar
Default Crackle and Wrinkle paint textures.
Forum members who are familiar with the Heathkit range of kits - receivers, transmitters, test gear and so on, will know that they were often finished in a distinctive greeny coloured paint.
I wouldn't call it "crackle" - maybe "wrinkle", and more matt than gloss.
I've never seen anything like it on sale, and of course it was factory finished -not from an aerosol can.
I wonder if any forum member has come across an acceptable substitute?
I won't hold my breath!
Thanks for reading.
David.
G4EBT
David G4EBT is offline
Old 5th May 2007, 2:56 pm   #2
igranic
igranic's Avatar
Default Re: Heathkit Paint?
First, for clarity's sake, let's make a clear distinction between 'crackle' and 'wrinkle' paint finishes.
This is an example of the 'crackle' finish beloved of interior designers, which I have seen used in red on a 1940s Ever Ready Portable, but never on a Heathkit.
[IMG]http://farm1.static.***********/169/415895037_50c5da2a1f.jpg[/IMG]
Whereas, wrinkle paint, in close-up, looks like this, and is similar to that used on some heathkits:
http://www.tomyang.net/cars/wrinkle2.jpg
Grey (and red or black) 'VHT Wrinkle Plust aerosol spray paint is available in the UK from USAutomotive, but it has been suggested that this could, when fully cured, be oversprayed with thin coats of the appropriate colour in order to achieve the desired textured finish.
For the appropriate overspray colour you could try a made-while-you-wait paint match aerosol. These are often available from local specialist automotive paint suppliers or motor factors. Or you could try Halfords Paint Match, but I personally would not go there expecting expert assistance.
HTH
Edward
Last edited by Darren-UK; 11th Dec 2007 at 1:34 am. Reason: Retail price reference removed.
igranic is offline
Old 5th May 2007, 3:15 pm   #3
mikelect
mikelect's Avatar
Hi David, I had the same problem and after much searching ended up having the case of my Mohican bead blasted and powder coated, with a very close colour, I was quoted £15 but when I collected it he charged me £5 (nothing wrong with the job and said his dad did it !!!) just lucky I guess but other places quoted me £35 plus materials. Another alternative I considered was to have the paint matched at a decorators supplies but there was a minimum quantity of 2 litres, I did find the correct colour in an aerosol in the USofA but they aren't allowed to post it so a no go, the paint is actually a type of silk/matt finish, hope this is some help
Mike
mikelect is offline
Old 5th May 2007, 6:19 pm   #4
plumbweiss
our local B&Q warehouse has a colossal range of textured radiator paint aerosols with crackle, wrinkle, hammered, rusted, what-have-you! I cant guarantee the correct colour but the texture is a start..
plumbweiss is offline
