13th May 2014, 9:05 am | #1 |
Restore 121 wooden case
What is the best thing for stripping the varnish off the case and the what do I use to restore finish.
I hope someone can help please |
13th May 2014, 8:11 pm | #2 | |
Re: Restore 121 wooden case
Use a shave hook always in the same direction of the wood grain, to remove the softened varnish layers, once all the varnish and stripper have been removed, finish with a light sand, then use fine wire wool to buff and remove any small traces in the wood grain. If the bare wood has patches of age discolouration an amount of judicious even sanding using a fine grade should even out the tone of surface. If you intend to re varnish, I prefer using several coats of solvent based clear varnish, once fully dry then use bees wax, though instead of varnish you could use bees wax directly, either gives a depth to the appearance to wood grain. |
13th May 2014, 8:12 pm | #3 |
Hi Graham,
have you tried the search facility at the top of the page for 'remove varnish. It gives many hits. Also there is a forum here for Cabinet and Chassis Restoration. Good Luck - Mike |
13th May 2014, 8:53 pm | #4 |
Hi Graham, I also should said I also use the long leading edge of a flexible stainless steel strip as a scraper on larger flat surfaces, it removes varnish much more evenly, much better than a shave hook. But Mike is right there are a number of posts on the forum that would be worth a read.
regards Kev |
13th May 2014, 8:59 pm | #5 |
These cases are made from very good quality, solid hardwood so are quite easy to work with.
I used Nitromors + various scrapers/shave hooks and wire wool, and re-finished with wax. However, you should establish that the original finish is beyond saving before stripping it off! Nick. |
13th May 2014, 10:21 pm | #6 |
Incidentally, what is a 121? To me it means a wooden wall-mounted telephone. I ask mainly to get an idea of the size and nature of the surfaces involved.
Also, I go along with Nick that stripping existing finish is a last resort ... but we all have different views on such matters - which have been aired in detail on these forums before!
13th May 2014, 10:29 pm | #7 |
I assumed it was a phone, Dave, but I could be wrong!
14th May 2014, 10:05 am | #8 |
Hi Graham,
I, and I am sure others, would appreciate some 'before' photos. And eventually some 'after' ones. Thanks - Mike |
14th May 2014, 10:56 am | #9 |
Many thanks for all your help I am new at this, and want them to look good. They were sold a spare parts. Photo as requested
Regards Graham |
