Old 6th Aug 2020, 8:41 pm   #1
alan rivis
Default Clockwork Turntable.
Hi.
Can anyone help with information on a clockwork turntable, it is marked 7A on the motor has a side winding handle and a Bakelite arm for the needle. It also has a cable out which I believe went to an external speaker amp that plugged into a light socket. The turntable case is home made, looking at the quality of the woodwork and the word Typhoo on the base panel.
Thanks, Alan.
alan rivis is offline
Old 6th Aug 2020, 10:12 pm   #2
Station X
Station X's Avatar
Default Re: Clockwork Turntable.
Hello and welcome to the forums.
It would help if you could post some pictures of your turntable.
Graham. Forum Moderator
Station X is online now
Old 7th Aug 2020, 9:58 am   #3
Audio1950
What specific information do you need Alan? What you have is the motor from a wind-up gramophone, probably a Garrard, with a later arm, in a home-made wooden box. If the cable comes out from the base of the arm, then it is intended to be plugged into the "gram" sockets of an old valve radio.
Barry
Audio1950 is offline
Old 8th Aug 2020, 9:20 am   #4
davidw
davidw's Avatar
Maybe this motor, scroll to bottom of page...http://www.gramophonemuseum.com/garrard-columbia.html
Dave G1AGK.
My perception is my reality!
davidw is offline
Old 8th Aug 2020, 9:01 pm   #5
Viscount
TYPHOO !!!!obviously a home brew set up i recon
Viscount is offline
