Where To Get Sets and Parts For discussions about swapmeets, rallies, NVCF and BVWS, car boot sales, antique and charity shops, dealers, newspaper adverts, the local tip and just about any other source of equipment (other than eBay). |
26th Jun 2020, 2:05 pm | #1 |
Axial 1kV/1.5kV LCR PC/HV/S capacitors
Prompted by seeing an enquiry in the wanted section, I have just checked whether my favourite high voltage axial capacitors were still available from CPC and found the range is reduced and the prices much higher than last time I looked:
https://cpc.farnell.com/w/c/electron..._1000002_EN_GB Farnell still stock a few more values, all at higher prices: https://uk.farnell.com/w/c/passive-c..._1000002_EN_GB They are still cheaper than the alternative Kemet A72 series at RS, though: https://uk.rs-online.com/web/c/passi...Term=Kemet+A72 |
26th Jun 2020, 3:09 pm | #2 |
Re: Axial 1kV/1.5kV LCR PC/HV/S capacitors
I fear that this is a sign of the times! The go-to 400V and 630V Vishay 1813 axial polyesters have been steadily creeping up and up in price in the last few years too. Someone in China is churning out lots of reasonably-priced yellow look-alikes with steel lead-out wires in a 630V rating, but I'm not sure about higher voltage ratings.
29th Jun 2020, 1:47 pm | #3 |
Where do you guys get the smoothing caps from?. Axial Kemet capacitors rated 500+ volts are ridiculously expensive and I'm struggling with high voltage radials as well, at least the ones from reputable brands. Availability from major suppliers seems to be hit and miss.
Having had a new capacitor (rated at 600v) fail and take out the rectifier in my GEC after only occasional use, the low cost Chinese ones will remain an option of last resort for me. Gabriel |
29th Jun 2020, 6:07 pm | #4 |
Have you tried Cricklewood Electronics? They are trading online and they post PDQ. My only connection is that I have bought from them and had good stuff at reasonable prices and quick delivery (then again, I am in the same city as them, London).
29th Jun 2020, 9:12 pm | #5 |
Don't forget the BVWS stock capacitors I find them to very good and not expensive. That said I have never bought via mail order I have always stocked up at an event.
29th Jun 2020, 10:17 pm | #6 |
Going over 500V rating does seem to be a difficult area with electrolytics- "570V MAX" is the highest I've seen on '30s HT electrolytics and things don't seem to have greatly advanced since with uncommon modern 600V types having somewhat poorer temperature, ripple rating, ESR, life expectancy etc. than their 500V stablemates and being disproportionately larger and more expensive, all else being equal. There's obviously a fundamental limitation at this sort of voltage. The world of HF inverter drives has produced high-capacitance plastic film capacitors of 1 to 100uF+ at voltage ratings ranging from 630V to well over 1000V whose ripple current ratings and ESR make electrolytics look pretty lame- whilst they're still somewhat larger and more expensive than comparable electrolytics, it's a competitive market and the difference is less marked than it was in the past.
30th Jun 2020, 11:49 am | #7 |
Another source is Just Radios in the USA,with obvious shipping difficulties. They do a minimum order of $25 + shipping, but stock 600V electrolytics and othe high-voltage capacitors:
https://www.justradios.com/cart.html Again, no connection except being a satisfied customer. if you are looking for really high voltage stuff, try this: http://hvstuff.com/ I've never bought from them so I can't really comment further, other than to say I have no connection. Perhaps you could make your mind up while sitting in one of the massage chairs that they sell, too! Colin. |
30th Jun 2020, 12:43 pm | #8 |
Thanks for the replies. Ive bought from crinklewood in the past. I don't think I buy in enough bulk to justify buying capacitors from the states just yet.
Does the bvws have an eBay or Facebook marketplace presence? I would do with a few bits and bobs. Gabriel |
1st Jul 2020, 11:22 am | #9 | |
2. To buy BVWS capacitors, I think you have to be a member and it's absolutely verboten to get a member to buy for you. I am not a member myself, but several are present on this forum and might be able to give you advice on membership. Colin. |
1st Jul 2020, 3:53 pm | #10 |
All they say is that It's forbidden to sell them on for profit, which is reasonable. Beyond that they become your property. Not all meetings are members only, and you can buy them there as a non-member as far as I know.
Even members only meetings welcome a signed in guest, who can join there if they want. The only exclusion is bidding at auctions, strictly members only. |
2nd Jul 2020, 5:25 pm | #11 |
Another up for the BVWS capacitors. Great range including high voltage, high quality electrolytic capacitors and postal order as well as the stand at the BVWS events. Used for all wax/Hunts capacitor replacements for radio and television sets.
Christopher Capener
