11th Jun 2020, 9:20 pm | #21 | |
Re: Cutting hole in 1/8" ali panel
https://www.ebay.co.uk/itm/ROUND-Roc...D/264063586906
George |
12th Jun 2020, 5:30 am | #22 |
Fettling ali can be a pain, clogs small drills and files but I routinely do holes with the method David used without a vice, a drill and file is all you need, doesn't take long. A coarse file helps, the type they use for finishing horse shoes.
The problem with dremel type drills with cutting disks is that it's hard to start the cut and then maintain the cut without breaking the disk or it skipping and then ruining your finish. The little grinding bits get clogged and if your not careful bite into the ali. It's well known that aluminium is Northumbrian cheese made on a grey cloudy winters day, the cheese goes grey as a result, they then roll it into sheets. Andy.
12th Jun 2020, 10:47 am | #23 |
Try these for cutting aluminium. Bought off Ebay note the wide cutting edge not just a saw edge more like a chisel ,I was very impressed with the results a squirt of WD helped. Mick.
12th Jun 2020, 4:23 pm | #24 |
As a born and bred Northumbrian I can confirm that what Andy says is true ;-)
12th Jun 2020, 10:19 pm | #25 |
Like others have said - mark it out with a very fine line then chain drill and file.
My instructor always said aim to split the scribed line - works every time and the more often you do it the easier / better it gets. I actually find doing a 'good job' of the metal work by hand strangely satisfying ! That said I do have a good selection of Q max cutters for more popular standard sizes. Thinking about getting a small desk top CNC for front panel engraving jobs.
Building and tinkering for over 50 years, from 807's to digital amateur TV. |
