Forum Announcements and Comments Announcements about forum changes will be made in this section. All new threads here now require moderator approval. |
8th Jun 2020, 6:22 pm | #1 |
Deleting private messages
Ho do I delete PMs on the forum? Can’t find an option to do so? I bet this is just one mouse click away. I have nearly 200 messages dating back a few years.
Failing to prepare is preparing to fail ... |
8th Jun 2020, 6:28 pm | #2 |
Re: Sorry, uhm
Just select the message(s) using the tick boxes on the RH side, then scroll down, and on the bottom right, change the "move to folder..." dropdown to "delete". Then click "go".
HTH, Nick. |
8th Jun 2020, 6:34 pm | #3 |
Re: Sorry, uhm
At least you're a long way off the point when the forum starts nagging you!
8th Jun 2020, 9:44 pm | #4 |
Administrator
Re: Deleting private messages
You can also delete them individually by viewing it, scrolling to the botton of the page and using the options there. For clearing out messages though the method Nick described is quicker.
9th Jun 2020, 6:03 am | #5 |
Why is the inbox set by default to "move to folder" and the sent to "delete"? I recently cleared out my PM folder, took ages, wish there was a "delete all read" like on my mobile phone. Yes I know i should delete regularly but who does?
I really wish there was a "search" option too, the amount of times I've had to trawl through pages of PM's looking for one PM with an address. If I could look up "Davetherave" for instance that would be nice. One sometimes gets around 20 PM's about a bit of gear, these being mixed in with scores of other PM's. These being observations not criticisms. Andy.
Curiosity hasn't killed this cat...so far. Last edited by Diabolical Artificer; 9th Jun 2020 at 6:09 am. |
9th Jun 2020, 7:33 am | #6 |
Sorry, now I know. Thanks guys. Quite obvious now.
9th Jun 2020, 7:53 am | #7 |
A partial answer is that the "sent" items can't be moved to a folder - only those in the inbox. Unfortunately, this seems to be a "feature" of the forum software. I appreciate that this doesn't answer why "delete" can't be the default for inbox.
9th Jun 2020, 8:36 am | #8 | |
Administrator
I would assume it is so the default option is the less destructive one, so if chosen by mistake it can be undone. Again though that's just how the software is. |
