Old 5th Jun 2020, 3:30 pm   #1
eddie_ce
eddie_ce's Avatar
Default Bakelite advice requested
I have just washed/scrubbed the case of my T401 in hot water and household cleaner. Years of dirt and nicotine seem to have come off, the water ended up looking like strong tea. However, as soon as the case has dried it looks very matt and disappointing.
Searching the forum it seems that the water/cleaner treatment was wrong.
How can I return the case to its former glory? Would using wax or polish help? I am worried using T-Cut as an abrasive cleaner/polish might make things worse.
I am pleased with the electrical restoration and it would be a shame if this radio were to be let down by the appearance of its case.
Thanks for any advice.
Eddie
BVWS Member.
Friend of the BVWTM
eddie_ce is offline
Old 5th Jun 2020, 3:49 pm   #2
Dave Moll
Dave Moll's Avatar
Default Re: Bakelite advice requested
Greygate Paste Polishing no. 5 (link is just to one sample of many) would be a good starting point.
Dave Moll is online now
Old 5th Jun 2020, 4:54 pm   #3
pip5678
pip5678's Avatar
I have used T Cut type products with no problems and the Greygate polish is probably even coarser, Brasso type metal polish works too, Bakelite is much more resilient than car paint!
pip5678 is offline
Old 5th Jun 2020, 5:28 pm   #4
emeritus
A work collegue who had inherited a DAC90 that had spent most of its life in a sunny bay window, used brown shoe polish to restore the finish and colour.
emeritus is offline
Old 5th Jun 2020, 5:29 pm   #5
Nickthedentist
Nickthedentist's Avatar
I think you're right, Eddie, but no point in crying over spilt millk, as we say.
I would indeed try Dave's recommended polish - it's excellent.
If that's not enough, you can often use woodstain to restore the colour, then protect with a wax polish to give it a bit of shine back. Not ideal, but it can look very good.
Or shoe polish as Emeritus has suggested.
Nick
Nickthedentist is offline
Old 5th Jun 2020, 5:41 pm   #6
vinrads
I have used Briwax and Oxblood shoe polish don't worry you will get the shine back. I always wash my Bakelite cases in soap and water. Mick.
vinrads is offline
Old 5th Jun 2020, 5:47 pm   #7
Reelman
Reelman's Avatar
I have a 332 Bakelite telephone made up of parts from various sources that was covered in different paints. After cleaning and scraping it all off the surface was matt, scratched and no longer completely black. The Bakelite polish* sold by the Radiophile made it shiny but did not restore the black colour. Black shoe polish did the trick.
*although a plain white tube I presume this is also Greygate’s.
Peter
Reelman is offline
Old 5th Jun 2020, 6:00 pm   #8
The Philpott
The Philpott's Avatar
...Whatever you treat it with- allow it to dry (but not force dry) thoroughly beforehand. We don't want any moisture to be sealed into it! I'm sure it'll be fine.
On an old black Avometer which had totally lost it's surface polish (i think it came out of the mould 'wrong' at the factory, in actual fact) i got good results with baby oil.
I think in your case there are better things to use (ie one of the things already suggested)
Dave
The Philpott is offline
Old 6th Jun 2020, 4:37 pm   #9
eddie_ce
eddie_ce's Avatar
Hi Guys,
thanks for all your advice and words of encouragement.
I have ordered some Greygate Number 5 and will give that a go.
Vinrads, do you mean the old type shoe polish which came in a round tin or this new fangled liquid stuff applied with a sponge?
Eddie
BVWS Member.
Friend of the BVWTM
eddie_ce is offline
Old 6th Jun 2020, 4:49 pm   #10
Luxman1050
Luxman1050's Avatar
Brasso works a treat slightly abrasive so gets dirt etc off then buff off will shine like new.
Luxman1050 is offline
Old 6th Jun 2020, 5:08 pm   #11
Dave Moll
Dave Moll's Avatar
Personally, I would use the polish that comes in a tin and apply it with a piece of cloth - likewise polishing it off again with a cloth - but then, that's what I use for my boots. Being an old dinosaur, I've never used the liquid stuff.
Old 6th Jun 2020, 6:13 pm   #12
Luxman1050
Luxman1050's Avatar
Couple pics using brasso on one of my radios was an absolute mess when I got it. But have used it on telephones, transformers, valve bases etc always worked a treat.
Pics might not be brilliant.
ID:	207834   Click image for larger version
ID:	207835   Click image for larger version
Old 12th Jun 2020, 3:54 pm   #13
eddie_ce
eddie_ce's Avatar
Well, the GG5 arrived this lunchtime, and what can I say, as you predicted, it has done its magic. I am well pleased.
Just one question, I used a clean cloth and despite having previously scrubbed the case twice in warm water and detergent the cloth took on quite a chestnut brown colour. Is this colouring the remainder of some stubborn nicotine staining or is it some constituent of the bakelite itself?
I have started a new thread regarding cleaning of the dial if you are able to help.
Thanks for all your advice.
Eddie
BVWS Member.
Friend of the BVWTM
eddie_ce is offline
Old 12th Jun 2020, 4:14 pm   #14
Nickthedentist
I'm glad it worked.
It's good stuff, originally specified by our post office when customers' telephones were being restored.
I think the brown on the cloth is from the Bakelite, but I'm not certain. Either way, if the end result is good, that's what matters I suppose.
Nick.
Old 12th Jun 2020, 4:19 pm   #15
ThePillenwerfer
ThePillenwerfer's Avatar
The brown stuff will be Bakelite. Polishing works by removing the high points so they are what will be on the cloth.
ThePillenwerfer is offline
