Old 15th Jan 2019, 12:29 am   #141
19Seventy7
19Seventy7's Avatar
Default Re: CRT is brighter to one side [Hitachi CTP213]
I'll have a look tomorrow when I get home. I think there was some replacements done in the past, as the soldering looks slightly different to the usual precision soldering.
Thank you all for your help!
19Seventy7 is offline
Old 15th Jan 2019, 11:34 pm   #142
19Seventy7
19Seventy7's Avatar
I've just had a look, and I think I've found a crack. I'm not 100% sure if it is a crack, I did think it could be some dirt but I got some IPA and a cotton bud, and cleaned the area and it didn't make a difference.
The crack is next to a capacitor I replaced, so could be because of this.
How would I fix it? Do I need to get another capacitor and keep the leg and fold it over, or is there another way?
Thanks
Old 15th Jan 2019, 11:38 pm   #143
ben
ben's Avatar
See Refugees post 137 on how to repair the cracked joint.
No need for a new cap at this stage, just resolder.
Regards,
Ben.
ben is offline
Old 15th Jan 2019, 11:43 pm   #144
19Seventy7
19Seventy7's Avatar
Sorry if this is a simple thing, but should I resolder the tracks, or the feed outs to the track, as I cut the remaining metal off the feed outs back when I replaced the caps.
Thanks for the fast reply!
Old 15th Jan 2019, 11:53 pm   #145
Lucien Nunes
Scrape away the solder-mask for a few mm either side of the crack. Either bridge with a nice smooth blob of solder, or if the crack has opened even slightly, preventing the solder flowing across, solder a little piece of tinned copper wire like a cut-off component lead across it. There's no need to disturb the capacitor
BTW, are you using 60/40 leaded solder? You should be, as lead-free solder will not work well on old equipment that was made with leaded, and your joints will be poor.
Lucien Nunes is offline
Old 16th Jan 2019, 12:01 am   #146
ben
ben's Avatar
I don't usually link to this sort of thing - too much clickbait and half-baked 'advice' from people who don' t really know what they're on about - but this shows quite well how to prepare the board trace prior to remaking the joint.
Regards,
Ben.
ben is offline
Old 16th Jan 2019, 12:33 am   #147
19Seventy7
19Seventy7's Avatar
Hi, thanks for the replies.
Ben - Thanks for the link, I’ll have a read of that after writing this.
Lucien Nunes - Thanks for your help - It’s really appreciated. About the solder, im not sure. I have a kit that was given to me so i’m not sure which it is. I use the solder which is given in the kit.
I can have a look tomorrow to see if there is any information in the kit, but i don’t think there is.
Thanks
Old 18th Jan 2019, 11:01 pm   #148
19Seventy7
19Seventy7's Avatar
Update:
PCB didn't have a crack, it was just some grime which looked like a crack.
I guess my next shot is to have a look at the resistor and diodes which were mentioned before my 1100 Man.
Old 21st Jan 2019, 8:52 pm   #149
19Seventy7
19Seventy7's Avatar
I'm just about to test the components 1100 Man said to test, diodes, resistor and capacitors.
I was unsure of which to test for a diode as it's said CR703 has gone short circuit, but is then said to test CR103
The most likely is that the diode CR703 has gone short circuit. It could also be C731 or C850 although these are both small value non electrolytic types so are not that likely to fail. You would need to test CR703 with a multimeter to confirm if it has failed.
Should I test CR703, or CR103.
Thanks
Old 21st Jan 2019, 9:47 pm   #150
1100 man
1100 man's Avatar
"Should I test CR703, or CR103."
That would appear to be a typographical error on my part- sorry about that! CR703 is the suspected diode.
Have you now got a multimeter ?
Nick
1100 man is offline
Old 21st Jan 2019, 9:51 pm   #151
19Seventy7
19Seventy7's Avatar
I did think it was CR703, just wanted to make sure.
I do, and I have also tested R727, which is allowing no current through at all. - Replacement being ordered soon
I will now test CR703, and come back with my results.
Thank you for your help!
Old 21st Jan 2019, 10:41 pm   #152
19Seventy7
19Seventy7's Avatar
I don't know if I'm doing something wrong, but I cannot get a result from CR703, either.
I'm not too bothered about R727 not giving a result, as either way I'd like to replace it, due to the burn on it.
Any help would be appreciated as to how to get a reading/why i'm not.
Thanks
Old 21st Jan 2019, 11:01 pm   #153
1100 man
1100 man's Avatar
What setting do you you have your multimeter on and how are you actually testing the diode?
How did you test the resistor R727?
Nick
1100 man is offline
Old 21st Jan 2019, 11:12 pm   #154
19Seventy7
19Seventy7's Avatar
My multimeter is on the diode setting with the diode symbol, and I have put red on the left side, black on the right, and visa versa with no luck either way.
Edit: This is on top of the PCB, where I can see the diode itself
I did the same with the resistor (switching wires over) but cannot remember which setting, I went through various settings.
Thanks
Old 24th Jan 2019, 12:05 am   #155
19Seventy7
19Seventy7's Avatar
I think I will replace diode CR703 just to be on the safe side as I can't get a reading on the multimeter.
What type of diode would this be as it has no information in the service manual
Thanks
Old 28th Jan 2019, 6:14 pm   #156
19Seventy7
19Seventy7's Avatar
Hi
I thought I would link this thread to the now closed "What Diode?" thread.
"What diode?"
https://www.vintage-radio.net/forum/...d.php?t=153497
Right, so the diode isn't crozzled? The resistor is? Do you know it's value, I think not if it's charred. Lawrence is your guy for that. As I said earlier, the diode is probably OK. Some confusion arose and it was assumed it was the RGB diode that had failed but that would result in an over bright raster. I think we all have a better idea as to which components have failed, but be aware when you restore your raster you will still have the shading. When you ascertain the value of the said resistor and replace it you "may" get your picture back. Have you no idea why it failed, because of where it is in the set it's unlikely to be a safety resistor, but not being terribly familiar with that model who knows.
The diode hasn't burned, the resistor had; which I got wrong in the linked thread as I mixed the two up and said the diode had burnt.
The resistor is a 1.8kohm metal oxide resistor. I have ordered a replacement, valued at 2watts which I was told should be okay.
How do I fix the shading? I was told replacing two capacitors would sort this, which I have changed, and that's when I had no picture.
Thanks
Ah right so it is the A1/screen diode, the confusion earlier was down to me, as I was under the impression it was the RGB 200v supply that was in trouble, my mistake.
Okay, do you know which A1 it would be from the list (See attached) as there are multiple.
Thanks
Thank you all for your help! It's really appreciated.
Old 28th Jan 2019, 6:31 pm   #157
Graham G3ZVT
Graham G3ZVT's Avatar
There is not enough context in that image for me to know what A1 means, I suspect there is a physical PCB layout diagram associated with it, with X-Y co-ordinates.
What we mean by A1 however, is the CRT first anode.
I don't blame you for misunderstanding the jargon which must be new to you.
Graham.
G3ZVT
Graham G3ZVT is online now
Old 28th Jan 2019, 6:54 pm   #158
19Seventy7
19Seventy7's Avatar
Oh my mistake, I just get a little confused at times.
I don't know how to read schematics very well, I just find them useful for finding parts on the board more than anything.
My guess that diode could be CR092 or CR093? i could be very wrong.
Thanks.
Old 28th Jan 2019, 6:56 pm   #159
19Seventy7
19Seventy7's Avatar
Maybe these photos could help?
Edit: 2nd image is location D7
ID:	177279   Click image for larger version
Old 28th Jan 2019, 7:07 pm   #160
ms660
ms660's Avatar
I deleted a post in error....here it is again:
……...Look at the document header! A1 is the location square on the schematic....
I've already pointed out what diode is what so far as CR703 (the subject of the diode thread) is concerned...…(location square D7 on the schematic)
EDIT: Post crossed.
Lawrence.
ms660 is offline
