Old 27th Nov 2020, 10:57 am   #21
DMcMahon
DMcMahon's Avatar
Default Re: ITT SL 530 Cassette Recorder Check Out
It is still running well, so (touch wood) looks like the hum issue is resolved.
Some of the soldered connections that were resoldered were not earth/ground connections, but I think most likely the root cause was due to bad ground soldered connection (s).
Final thing to sort out is the tape counter to try and fix the reset mechanism, will get back to that sometime later as other more important things to progress.
DMcMahon is offline
Old 14th Feb 2021, 6:41 pm   #22
DMcMahon
DMcMahon's Avatar
Originally Posted by DMcMahon View Post
Attached is a short extract of a MP3 test recording, it is German and the track is titled "Symbolism" and I am pretty sure no body would be able to identify the unknown artist.
Artist was SD77 (Alexander Kunz and friends) from the 2008 Album epilog.
DMcMahon is offline
