Sets, Parts and Service Information Offered (private sellers only, exact price required, no swaps) You may announce components or sets for sale or offered free here. Private collectors only - no traders. You must include an exact price. No swaps. |
15th Nov 2023, 11:14 pm | #1 |
Odds and ends clearout! Components, connectors etc - have a lOOk!
Hi All!
After moving (and a lot of sorting!), I have identified many useful items that are surplus to my own needs. All items are offered as-seen and on a first come basis (no hat) Postage: Large letter items £2 - £3 depending on weight Thicker/larger items £4 (Royal Mail small parcel) * As always, I'm happy to combine items into one package to save Postage costs. * Please leave a note in the thread with your requests, followed by a PM. I will get back to you with a total shortly 1. Casio FX-7000G vintage graphical / scientific calculator. In lovely clean condition, fully working with slip case and instructions £8 + post 2. 10x LCR FCSEX 220pf 1% polystyrene capacitors £2 + post 3. 15x Mullard/Philips 680uf 10V 108 Series long life capacitors. Measure excellent, great quality. £4 +post (or 3 lots for £10) 4. 2x Bulgin ruggedised momentary pushbutton switches. Could be used as joystick 'fire' button etc £3 +post 5. Lot of various vintage semiconductors, diodes, transistors, voltage regs etc. £3 +post
...where on earth did that spring/screw go?? |
15th Nov 2023, 11:15 pm | #2 |
Re: Odds and ends clearout! Components, connectors etc - have a lOOk!
6. 4x RS Shrouded safety 4mm plugs. New old stock.
£3 +post 7. 6x miniature toggle switches, quality items. New old stock £3 +post 8. Maplin 8W LM383 powerr amp module. Almost finished, just needs a trimmer pot to complete! £5 +post 9. 2x Maplin 3pole XLR LINE/cable plugs £2 +post 10. Neutrik Profi Phono plugs, 1 pair Top quality, pro phono plugs. £6 + post
15th Nov 2023, 11:17 pm | #3 |
11. RS Waveform Generator PCB, (untested)
£2 +post 12. Lot of polystyrene capacitors, many different and useful values £3 + post 13. Set of 4 Radio Shack gold plated 4mm banana plugs in sealed pack, nice quality £4 + post 14. 12x gold plated 4mm banana plugs (3 sets of 4) £4 + post 15. Bipak AL60 (mono) amplifier module (untested) £5 + post
15th Nov 2023, 11:18 pm | #4 |
16. 3x Spectrol Helical trimmer potemtiometers, super quality!
2x 2k5 , 1x 50k £3 + post 17. Maplin 15W Amplifier module (TDA2030) Untested. With diagrams, details etc £5 + post 18. 6x Voltage regulator PCB's (+ 2x regs) Ideal for making a PSU with minimum hassle! £3 + post 19. Lot of miniature valves, most appear to be new £3 + post 20. 6x Lemco 1000pf 350v Axial Mica caps £3 + post
15th Nov 2023, 11:19 pm | #5 |
21. Eagle LT44 20K - 1K transistor driver transformer
£2 +post 22. Radio shack gold pin connectors x4 (pin ~2.5mm diameter) £2 +post 23. 4x RS/CLIX hook terminal/spade connectors £3 + post 24. Lot of various 4mm, etc pin connectors £3 +post 25. Lot of vintage trimmer / preset trimmer resistors £2 +post
15th Nov 2023, 11:20 pm | #6 |
26. 10x Wearite radio coils, nice items, ex erquipment
Great condition £5 + post 27. Vintage panel voltage selector £2 + post 28. RS 12V + 12V low profile transformer. Dual 120V/115V primary £3 + post 29. Brass shaft extension. Grub screw x2 fixing. £2 + post 30. 0-12V mains transformer. Mulkti voltage primary input. £2 + post
15th Nov 2023, 11:21 pm | #7 |
31. 6x ferrite rings, various sizes as shown (largest = 37mm OD)
£3 + post 32. 36 SWG enameled copper wire, small '2oz' bobbin. (Fair bit left as shown) £2 +post 33. 0-12, 0-12V 6VA transformer £2 + post 34. 2x 100x160 photo sensitive fibreglass PCB boards £2 + post 35. Lot of tag strips, various as shown £3+ post ** END OF ITEMS **
15th Nov 2023, 11:23 pm | #8 |
Hi Rob.
I'd like to express interest in item #5 the mixed semiconductors. Thanks. Regards, Symon |
16th Nov 2023, 12:18 am | #9 |
Good evening,
Could I show an interest in No. 19 Lot of miniature valves. Many thanks, Christopher Capener
16th Nov 2023, 12:48 am | #10 |
Hi Rob
Good to see you back after your move, please may I have lot 26, the Wearite coils. Will await your pm in due course. Cheers Mike |
16th Nov 2023, 1:00 am | #11 |
I'd like to be considered for item 5 too if there is a hat and not first past the post.
Craig
Doomed for a certain term to walk the night |
16th Nov 2023, 1:09 am | #12 |
Hi Rob.
I would like item 15. Bipak AL60 (mono) amplifier module (untested) £5 + post. regards, Steve. |
16th Nov 2023, 1:12 am | #13 |
Hi Rob
I'd be interested in: #7 (toggle switch) and #35 tag strips for me please. Pm sent Thanks Gabriel |
16th Nov 2023, 1:23 am | #14 |
Hi Rob,
I can take 2,10,11,12,14 if that's ok? I shall drop you a PM now. |
16th Nov 2023, 2:54 am | #15 |
Some items sold/reserved pending payment.
The items still available are: 3. 15x Mullard/Philips 680uf 10V 108 Series long life capacitors. 4. 2x Bulgin ruggedised momentary 'push to make' switches. 6. 4x RS Shrouded safety 4mm plugs. New old stock. 8. Maplin 8W LM383 powerr amp module. 9. 2x Maplin 3pole XLR LINE/cable plugs 13. Set of 4 Radio Shack gold plated 4mm banana plugs 16. 3x Spectrol Helical trimmer potemtiometers, super quality! 17. Maplin 15W Amplifier module (TDA2030) 18. 6x Voltage regulator PCB's (+ 2x regs) 20. 6x Lemco 1000pf 350v Axial Mica caps 21. Eagle LT44 20K - 1K transistor driver transformer 22. Radio shack gold pin connectors x4 (pin ~2.5mm diameter) 23. 4x RS/CLIX hook terminal/spade connectors 24. Lot of various 4mm, etc pin connectors 25. Lot of vintage trimmer / preset trimmer resistors 27. Vintage panel voltage selector 28. RS 12V + 12V low profile transformer. 29. Brass shaft extension. Grub screw x2 fixing. 30. 0-12V mains transformer. Mulkti voltage primary input. 31. 6x ferrite rings, various sizes as shown (largest = 37mm OD) 32. 36 SWG enameled copper wire, small '2oz' bobbin. (Fair bit left as shown) 33. 0-12, 0-12V 6VA transformer 34. 2x 100x160 photo sensitive fibreglass PCB boards
16th Nov 2023, 9:12 am | #16 |
Good morning Rob,
Could I take items 29 and 33 please. Kind regards, David |
16th Nov 2023, 10:38 am | #17 |
number 30 please 12v transformer
33, 45, 78, around and around they go...
16th Nov 2023, 10:45 am | #18 |
23, 24 & 32 please.
Rod |
16th Nov 2023, 12:52 pm | #19 |
Could I have item 20, the 6 X Lemco cap's if still available please.
John |
16th Nov 2023, 1:24 pm | #20 |
6) shrouded plugs, 16) trimmer pots and 28) low profile transformer please.
David |
