Old 20th Jun 2010, 1:10 pm   #1
Peter.N.
Default Bridge rectifier protection
Hi folks
I have an old fast battery charger, well about 25 amps anyway, I replaced the selenium rectifier with a silicon bridge years ago, but I am now on my 6th at least. The slightest spark or overload seem to blow them up, one has just gone this morning and I only have one left. The rectifier is rated at 25 amps 1000 volts, is there anything I can do to protect it?
Thanks
Peter
Peter.N. is offline
Old 20th Jun 2010, 2:00 pm   #2
threeseven
threeseven's Avatar
Default Re: Bridge rectifier protection
Sounds like a reverse emf spike is popping a diode or 2. Is there a transient cap across the TX secondary ?
threeseven is offline
Old 20th Jun 2010, 2:46 pm   #3
Richard
Richard's Avatar
Hi
If the charger is rated at 25A continual, then a short circuit surge will be well in excess of this, I would be looking for a 50A rectifier min.
Richard
BVWS member.
Richard is offline
Old 20th Jun 2010, 3:52 pm   #4
Red to black
Red to black's Avatar
I wonder if it would benefit from "suppression capacitors" as shown in the Pic.
Just a thought.
Cheers,
Baz.
Red to black is offline
Old 20th Jun 2010, 11:07 pm   #5
McMurdo
McMurdo's Avatar
This is one of the reasons selenium rectifiers were used in chargers and welders long after silicon bridges were viable! In industry, they were used to drive brake coils and electromagnets because they can withstand high back emf.
Most modern silicon rectifier bridges in chargers and welders will have an MOV across the output to clamp any back emf. You can get some quite meaty ones for not much money.
Kevin
McMurdo is offline
Old 20th Jun 2010, 11:55 pm   #6
Peter.N.
Thanks for your comments folks. I have now ordered some 50A bridges and have fitted push on connectors to speed up the change time. I had wondered about suppression caps as used in TVs but wasn't sure that they would be effective at that sort of current.
Kevin
Pardon my ignorance but what it an MOV?
Peter
Peter.N. is offline
Old 21st Jun 2010, 12:00 am   #7
wave solder
wave solder's Avatar
Wikipedia explains what an MOV is excellently:-
http://en.wikipedia.org/wiki/Varistor
wave solder is offline
Old 21st Jun 2010, 12:53 am   #8
glowinganode
glowinganode's Avatar
Fitting supressor caps /mov's as per the other posts is always worthwhile, though I doubt the rectifiers are failing through exceeding the vrrm.
Are they failing open circuit or short?
To get anywhere near 1000V across the secondary would require around 20kV across the primary (all things being equal).
As the load is in effect capacitive, the peak current can be several times the mean current. The higher esr of a selenium resistor would tend to reduce the peak current.
Definately fit a 50A device and try adding a bit of series resistance to take the edge off, a few ohms suitable rated in series with the primary may help.
Rob.
We have done so much, for so long, with so little, we are now qualified to do anything with nothing.
glowinganode is offline
Old 21st Jun 2010, 9:43 am   #9
Peter.N.
They are going s/c, Yes, I see your reasoning re peak voltage so perhaps its just excessive current.
VDRs I am familier with as also resistances and condensers, didn't know they had renamed them
Peter
Peter.N. is offline
