Old 14th Oct 2009, 9:21 pm   #1
Oldtimer74
Default Cine to CD conversion
Not sure if this is the right place to ask (or even the right forum). Can one transfer cine film to CD or is the equipment so expensive that only professional companies can do it?
Pat G3IKR
Oldtimer74 is offline
Old 15th Oct 2009, 7:05 am   #2
dseymo1
Default Re: Cine to CD conversion
Surprisingly good results can be obtained using just a projector and camera. I have one of those preview rear-projection screens, which works well, but a strightforward mirror should be OK - just watch out for 'hot spots' due to an incorrectly set up lamp / condenser.
dseymo1 is offline
Old 15th Oct 2009, 8:55 am   #3
KeithsTV
KeithsTV's Avatar
I've used a similar method projecting the image onto an A4 sheet of white paper. with the camcorder next to the projector. I found it best to disable the auto focus and focus manually to get the best picture. There's a small amount of flicker on the finished video which may or may not be objectionable.
Keith
KeithsTV is offline
Old 15th Oct 2009, 10:06 am   #4
peter_scott
peter_scott's Avatar
It also helps if your camera has slow shutter selections otherwise you can get flicker problems.
Peter
peter_scott is offline
Old 15th Oct 2009, 11:50 pm   #5
Oldtimer74
Thanks gentlemen for useful advice.
Thread can now be closed
Pat G3IKR
