Old 22nd Oct 2021, 8:07 am   #1
Sleator
Default Radiogram Wiring Diagram. BSR Deck.
Hi, I have been asked to look at a,
Vintage Valve Radiogram Monarch BSR Model B55 TAG Radio &amp.
From my inital look, some of the wires are missing or broken.Does anyone know where I can get a wiring diagram for this model or any suggestions.
Thanks for an help
Eddie
Sleator is offline
Old 22nd Oct 2021, 9:26 am   #2
Herald1360
Herald1360's Avatar
Default Re: Wiring Diagram
BSR Monarch xxxxx is just the record player deck, it doesn't help to identify the actual radiogram make and model. This would normally be marked on the rear panel or perhaps the radio/amplifier chassis itself. A few clear pictures may also help.
Unfortunately, if the set was manufactured in the RoI, service information may be hard to find......
....__________
....|____||__|__\_____
.=.| _---\__|__|_---_|.
.........O..Chris....O
Herald1360 is offline
Old 22nd Oct 2021, 10:21 am   #3
Cobaltblue
Cobaltblue's Avatar
Default Re: Radiogram Wiring Diagram. BSR Deck.
As a complete excercise in lateral thinking could it be the Radiogram version of this :
https://www.radiomuseum.org/r/banner_b55.html
Banner in RM show a model B55TAG
If so the Chassis is likely to be the same as the Sobell 515
Mike T
Mike T BVWS member.
www.cossor.co.uk
Cobaltblue is offline
Old 22nd Oct 2021, 10:31 am   #4
Station X
Station X's Avatar
Service data here:-
https://www.service-data.com/section.php/7506/1/515tag
Graham. Forum Moderator
Station X is online now
Old 25th Oct 2021, 11:11 am   #5
Sleator
Thanks for all your help, I now think the info. I supplied is not correct, so I am attaching some pictures in a hope of identifying it. The radiogram is in a friends house, so progress is slow, I just want to see if it's worth fixing.
Any suggestions/help appreciated,
Thanks, Eddie
ID:	244179   Click image for larger version
ID:	244180   Click image for larger version
Sleator is offline
