17th Oct 2021, 1:51 pm | #41 | |
Re: The death of terrestial TV transmission?
Been trying for 3 years to download The Conversation (Hackman) from a platform that my family subscribes to, eg, Netflix, Amazon.....still no joy. Lawrence. |
17th Oct 2021, 1:58 pm | #42 |
I like the way you can be chatting about something and then you can search for it on the web and watch the video.
We were chatting here about Pyrex TV tubes failing and following on with a video on U-tube done with a slow motion camera of a Pyrex item being enticed to explode. I like the ability to select topical viewing. |
17th Oct 2021, 2:51 pm | #43 |
Putting on a slightly radical stance...
Searching for "your stuff" (it is pushed on you by the method used by search engines) "content" merrilly reinforces a view. "Unwanted content" can, and should let us expand our horizons. To misquote Bowie (I think, it's been a while) "don't turn away the strange". |
19th Oct 2021, 1:25 am | #44 |
I would give terrestrial TV and Radio another 20-25 years. By then all broadcasting/streaming will be on line via direct fibre feed to your house or over the 5G, and what comes after 5G, network. Just as we do now with on line TV apps we will be able to watch or listen to TV/Radio live or whenever we want, wherever we want and use pause if we need to.
Simon BVWS member |
19th Oct 2021, 11:25 am | #45 | |
19th Oct 2021, 11:50 am | #46 |
https://www.bbc.co.uk/news/uk-england-tees-58821271 I would say from the carefully worded short video there’s little or no intention to replace Bilsdale with anything on the same scale. More concern is expressed about repairing the moorland. My guess would be that something similar to the temporary mast will most likely be erected at the main site. We shall see.
19th Oct 2021, 11:58 am | #47 | |
To quote from the article you linked to:-
19th Oct 2021, 12:09 pm | #48 |
We will be observing developments at SWMBO's with interest as she is in the 5% who still don't get a signal after the temporary mast was fired up.
We've acquired Freesat to get around the problem but that only serves the lounge (the currently broken terrestrial signal is distributed to sets all over the house). It also leaves several expensive Freeview recorder boxes lying around redundant, so we'd like to get the Freeview signal back eventually. |
19th Oct 2021, 12:48 pm | #49 |
Ah, apologies, the perils of only watching the video. Well spotted.
19th Oct 2021, 1:00 pm | #50 | |
19th Oct 2021, 6:38 pm | #51 | |
Personally I use a ZGemma 2xDVB-S box as a server and a second box as a client in another room. They work with a form of Linux and are very configurable but also fiddly to set up.. |
19th Oct 2021, 8:43 pm | #52 |
Has there been any announcement on the transmit ERP for the various multiplexes on the temporary Bilsdale mast ?
I suspect the aerial arrays will be a lot smaller to keep down the wind loading, and the much lower height will take its toll as well. What about the transmitters? The last time I saw a main station UHF transmitter, it wasn't exactly portable...
John G4FDD G-QRP 431 |
20th Oct 2021, 9:13 am | #53 |
The signal to noise ratio on this thread hasn't been wonderful. It's all speculation and some posts have wandered into areas political, maybe even conspiracy-theoretical.
It's time to sit back and just watch to see what happens. Whatever it is, it won't be perfect and we'll have no choice but to live with it. Perhaps it's a good time to invest in standards converters, pantry transmitters and recordings of favourites. David
