13th Oct 2021, 12:28 pm | #1 |
RIFA X2Y cap - would appreciate views
I see the exploding RIFA thread is closed, so afraid I need to open a new one.
I would appreciate views on the one shown below - I have a stock of them and have been using them for some while without issue, but of course the potential breakdown will creep up. FYI, they are ex-RS part number 239-668. The date code is September 2002. |
13th Oct 2021, 12:37 pm | #2 |
Re: RIFA X2Y cap - would appreciate views
If they were stocked at a constant temperature and low humidity, they'll probably be good a few more years. Otherwise and after that, they will prevent views by laying a smokescreen as they do.
13th Oct 2021, 12:41 pm | #3 |
They look just like the hard-epoxy Rifa capacitors that Ive had trouble with!
I'd be happy using for a short-lived bench prototype, if pushed - but not for anything expected to be still working in 10 years time. How they've been stored is important - out of sunlight, and in a dry environment, is best. |
13th Oct 2021, 12:41 pm | #4 |
Personally I'd throw them out. No virtue in fitting components which will inevitably fail at some point.
Alan |
13th Oct 2021, 12:57 pm | #5 |
All stored in their original sealed bag in a box in an indoor room temp cupboard.
These are still sold by RS (under the same part number) - so is the consensus that even a new one is a high risk? I'm struggling a bit with that... So what would be (less un)reliable alternative(s)? |
13th Oct 2021, 1:39 pm | #6 |
The basic principle of construction (potted impregnated paper) is flawed (antiquated, replaced by 1960 for most applications and by 1990 for all other applications, not at the right price point to make ones that last, etc.) and the execution is mediocre at best. Most X capacitors will fail at some point through wear and tear, but modern plastic foil ones will at least degrade gracefully and usually only with use, not with time. Any MKP (metallised polypropylene foil) replacement will be better, though quality may vary a bit by manufacturer.
The rationalisation for such MP capacitors to still be produced might be their past marketing still deceiving some people (RIFA was especially infamous for touting their superiority) and a conservative customer base (including NATO stock probably, retrofitting modern types might be expensive administratively). In the past, even up into the 1980's, they did fit a niche market for mains filters and RC-suppression circuits. Polypropylene was not yet cheap and reliable enough and the alternative was mixed dielectric (paper+polyester) which was only slightly more reliable. It was easy to import equipment fitted or retrofitted with those capacitors to pass local inspections, hence probably their marketing. P.S. The use as Y-capacitors in non-earthed equipment is especially dangerous as they might go leaky without warning. |
13th Oct 2021, 1:51 pm | #7 |
At least the potting on the one shown is not cracking so it might be OK for a few years. Any that show cracking of the potting should be treated with great suspicion since they are likely to have absorbed moisture.
13th Oct 2021, 3:32 pm | #8 |
Is it just me? There appears to be a couple of tiny cracks across the text "40\1....“ in the first picture, if the type PZB is metallised paper based and they looked like that, I wouldn't use them myself.
Some technical data has been unloaded here: https://www.vintage-radio.net/forum/...7&postcount=27 David |
13th Oct 2021, 3:39 pm | #9 |
No cracks at all - looked via a loupe to be sure. I think the strong sunlight reflecting off of the foil printed liner - which is very lined in itself - make sit look like the case may have fine cracks.
Funny about paper caps - if I found one in some valve gear, it would be straight out and into the bin... Has anyone found any relationship between insulation resistance and/or leakage and life expectancy? |
14th Oct 2021, 4:30 pm | #10 |
14th Oct 2021, 5:34 pm | #11 |
Just tested them with a Megger at 500V and 1000V: >50MΩ.
BUT put one across the mains and leakage = 8mA, which is a lot. To be precise, this was measured in the Live conductor fed from a isotran with no secondary earth - so this is all L-N (thru either X2 and/or the Y2s) and so I couldn't say what's going down the earth thru just the Y2s in normal use. No reason to assume it isn't in line with this. Tests closely in any of three of that batch. Looking at the values, I'd expect a reactance in the MΩ range at 50Hz, but I'm clearly seeing tens of kΩ instead. Unless I'm missing something? Bin it is. Potential for nuisance RCD trips here. |
14th Oct 2021, 5:55 pm | #12 |
RS 239-668:
https://docs.rs-online.com/de41/0900766b81717876.pdf https://www.electronics2000.co.uk/ca...calculator.php Which at 245VAC would be near as damn it 8mA. Lawrence. Last edited by ms660; 14th Oct 2021 at 6:07 pm. Reason: extra info |
14th Oct 2021, 6:11 pm | #13 |
I would throw them away and you won't have to worry about them.
As others have said, the likelihood of failure is too high to warrant using them and saving a little bit of money. They could potentially do very costly damage. In my opinion, it's just not worth the risk...
...where on earth did that spring/screw go?? |
14th Oct 2021, 6:26 pm | #14 |
You could downgrade them and use them for different applications. Personally I'd be happy to use them as HT decouplers in typical valve radios, and of course in low voltage circuits, though they're a bit physically big for that.
14th Oct 2021, 6:27 pm | #15 | |
I don't know how I mis-calculated that as I indeed used Xc = 1/(2PifC). Oops. |
14th Oct 2021, 6:29 pm | #16 |
I see KEMET do a 100R and 100nF in series suppressor cap - or 'snubber' I suppose we might say.
It's paper yet again, but of different build. https://docs.rs-online.com/e1d2/0900766b809c6e10.pdf |
14th Oct 2021, 6:39 pm | #17 |
Do not hesitate - throw them out. Save yourself pain, grief and acrid smoke.
Doomed for a certain term to walk the night |
14th Oct 2021, 6:45 pm | #18 |
Good to see you've decided to consign them to the skip: I never really understand why "NOS" parts that have undergone decades of ageing while sitting on a shelf somewhere are treated with such reverence [specially by the audiophools].
New parts are cheap [when you look at how many minutes even a minimum-wage worker would need to earn the cost of a new part compared to what they would have to have worked to buy an equivalent part in the 50s/60s/70s/80s]. These days the time/labour-cost of fitting a part often exceeds the cost of the part itself... so it makes sense to fit only the best-quality parts.
15th Oct 2021, 8:42 am | #19 |
Agree re best quality. Sadly our industry is swamped with low quality parts from you-know-where, but weeding out these sorts of duffers from more respected providers is almost more frustrating!
I always use Vishay VR25/37 resistors for bleeders across mains caps - another place where an unexpected pop isn't very desirable! |
