11th Oct 2021, 1:48 pm | #1 |
TS670 fitting FM board connections
Greetings.
I have recently purchased the above radio without an FM board, no problems there as they are the same as a TS430 of which i have a couple of for spares. What is not shown in the manual are the fitting instructions, i have it screwed into the radio, i also have found a 7 to 7 pin lead which i have connected but it is the other 2 x pin, there are 3, numbered 1,2and 4 on the FM board, i have a couple of looms that i may be able to rescue these leads from those. So after that novel what i am after is what connections from the FM board to the main boards. As always any advice is much appreciated. regards Snowy G0HZE |
11th Oct 2021, 2:14 pm | #2 |
Re: TS670 fitting FM board connections
Ok gents, all sorted, i hope, after much poring over the diagrams with the component placing i have managed to find the relevant info.
Cheers and Beers Snowy |
12th Oct 2021, 8:46 am | #3 |
Hi All, an update on the TS670 and the FM board, all fitted and receiving ok however NO TX, I will be doing voltage checks later this am, however if anybody has a copy of the fitting instructions they could scan for me i will gladly pay the costs and postage.
Its just to clear up in my own mind that what i have done is correct. Thanks in anticipation, Snowy |
13th Oct 2021, 6:35 pm | #4 |
All sorted now, turned out to be a faulty lead. cheers
