Old 6th Oct 2021, 3:42 pm   #1
German Dalek
German Dalek's Avatar
Arrow 12 Volt car battery voltage to 12/13,5 VAC 50Hz - 5/6 Watts
Hello!
I need a simple schematic to invert 12 - 13,5 VDC (car battery) to 12 - 13,5 VAC!
Consumption is only 5-6 Watts at clean 50 Hz!
Any ideas?
Thanks in advance!
Regards,
German Dalek
And now something completly different:
MARC BOLAN, he was/is the real king of Pop Music!
German Dalek is offline
Old 6th Oct 2021, 4:21 pm   #2
Default Re: 12 Volt car battery voltage to 12/13,5 VAC 50Hz - 5/6 Watts
May I ask what it is for? Is the clean bit frequency or waveform?
Old 7th Oct 2021, 6:40 am   #3
German Dalek
Good morning!
I have a (once pulled from Stereo assy) good high quality DUAL record player.
It is a really rare 12 VAC powered set.
I am always on the run hunting records on fleamarkets across Germany, France,
etc.
I don`t like these low quality battery-powered plastic record players/destroyers.
So far away from home I like to listen to some records I just have bought.
With a 9/12 VDC RIAA and the amp of a car
radio it will be possible to listen in the car, with a good sound and the (holy )
records cannot get damaged.
Of course I have some 12 VDC / 230 VAC supplies, but I like to do something
with that DUAL 496 RC.
So I am still hoping for a simple solution.....
Regards,
German Dalek
Old 7th Oct 2021, 10:38 am   #4
snowman_al
snowman_al's Avatar
Referencing the circuit diagram it looks like the only part that needs to be 50Hz (or 60Hz) is the strobe light. The rest runs off DC from the rectifier / cap stage.
Might even work off 12 volts from the battery? Or a 12 to 15 volt DC to DC converter? As long as the 'strobe' is not important in the car.
The User and Service manual are both available free online by the way.
Never Leave Well Enough Alone...
snowman_al is offline
Old 7th Oct 2021, 4:49 pm   #5
G6ONEDave
G6ONEDave's Avatar
Maybe a 50/60 hz timebase oscillator ic could be used for lighting the strobe and it would power from the 12vdc supply.
Dave
Quote "All is hyperthetical, until it isn't!" (President Laura Roslin, Battlestar Galactica)
G6ONEDave is offline
