Old 1st Sep 2021, 10:14 pm   #1
Cre8anet
Cre8anet's Avatar
Default Application?? Mystery Mini AC induction motor
Hi Folks,
Any ideas where this tiny ac motor came from?
It runs on only 6V a few 10s of mW ..but very low torque. It had a worm drive fitted so obviously geared right down.
Clock? Timer?… But why low AC V??
Found with various 50s / 60s kit.
Suggestions welcome!
Cheers,
Cre8anet
~~~~~~May your Waves be Long~~~~~~
Cre8anet is offline
Old 2nd Sep 2021, 3:01 am   #2
broadgage
Default Re: Application?? Mystery Mini AC induction motor
Possibly to operate a flap or damper for controlling air flow in an air conditioning system. Somewhat similar units are still used today, but more commonly in 24 volts AC.
Or perhaps to actuate a valve for heating or cooling control, again still made today but for 24 volts AC.
Or even to drive a number of mechanical cams that operate microswitches in a sequence. Used to control advertising signs in which differing parts are lit in sequence.
Or for other processes that require a controlled sequence, e.g. industrial laundry machinery, agitate clockwise for 2 minutes, then anti clockwise for 2 minutes, repeat this four times for a 16 minute wash cycle, then run drain pump for one minute, then spin for six minutes, for example.
Or to start a number of large electric motors in sequence, either to limit starting current, or for other reasons such as a large conveyor system.
broadgage is offline
Old 2nd Sep 2021, 11:45 am   #3
G6Tanuki
G6Tanuki's Avatar
It looks rather too expensively well-engineered to be something from a piece of consumer-gear; I'd suspect it had a professional use - something like driving a capacitor or roller-coaster in a 'remote' antenna tuner?
G6Tanuki is offline
Old 2nd Sep 2021, 12:06 pm   #4
Lucien Nunes
Extra-low voltage motors are cheaper and more robust than mains voltage due to the much shorter, heavier-gauge winding. There is often an advantage to avoiding having mains voltage on control contacts if the rest of the system is ELV and a suitable voltage is already available. So pinball gameplay camswitches, jukebox selector and accumulator drives etc can usefully run from the auxiliary supply e.g. 24V AC. I could see your motor rotating a colour wheel or something that requires near zero torque.
Lucien Nunes is offline
Old 2nd Sep 2021, 5:08 pm   #5
Cre8anet
Cre8anet's Avatar
Jolly good stuff - thank you all.
Yes, it is quite possible 24 VAC .. I tried ramping up the volts a bit.. but without the worm and gearing, the pole-sync gets a bit chaotic and it seems to stall / reverse.
(..was some old electricity meter kit with it... but I can't see that being low-VAC).
Cre8anet is offline
Old 2nd Sep 2021, 11:00 pm   #6
McMurdo
McMurdo's Avatar
is it definitely a motor, or just something that acts like one when you power it? Maybe out of a large electric clock? Or a rotary solenoid? Mercury switch actuator from a power-factor correction circuit? A motor with very little torque seems pretty useless to me!
Kevin
McMurdo is offline
Old 2nd Sep 2021, 11:48 pm   #7
Red to black
Red to black's Avatar
Some ELV low torque motors were used in various different makers/ point of sale shop signs etc, the colour wheel for such things has already been mentioned in a previous post.
I know we had a Toshiba sign that covered/uncovered various fibre optics that made the Toshiba sign lights look like it was sweeping left to right, a bit like a modern day Christmas tree type thing.
Red to black is offline
