Old 22nd Aug 2021, 8:58 pm   #1
Mgtstan
Default Knee-operated singer sewing machine 99K
My 1950 knee-operated singer has lost the ability to moderate its speed i.e. if you plug it in, it goes fast, and the only way to stop it is to unplug it.
You have threads about foot-operated versions. Any thoughts on how a knee-operated machine can be restored to functionalilty?
Mgtstan is offline
Old 22nd Aug 2021, 10:03 pm   #2
Graham G3ZVT
Graham G3ZVT's Avatar
Default Re: Knee-operated singer sewing machine 99K
Hi there and welcome to the forum.
My 99K has the more common foot controller but looking at this knee controller image on line, it looks to me that it is likely to be electrically identical to the foot controller.
No doubt you have seen other threads where the cause of the speed being stuck at maximum is a shorted capacitor inside the controller, so unplug the machine, unscrew the case of the controller snip out the capacitor, reassemble and test.
It will work fine without the capacitor it will just wipe out your neighbours AM radios, if you care (of course you care) let us know once you have restored the speed control, and we can help you source a replacement capacitor.
Graham.
G3ZVT
Graham G3ZVT is offline
Old 22nd Aug 2021, 10:32 pm   #3
paulsherwin
paulsherwin's Avatar
Yes, the knee controller is basically the same as the more common foot pedal, and it's very common for the suppression capacitors to fail. Just replace them with modern class X2 types.
paulsherwin is offline
Old 3rd Sep 2021, 4:25 pm   #4
Mgtstan
Thanks for your help.
I agree that the theory is the same as a foot pedal, but the physical layout is different.
The kneebar is connected to a mechanism that sits in the box to the right of the main machine. This appears to be purely mechanical, and I don't see a capacitor there.
The motor has a section added on to the outside, and I am attaching a picture of what you can see inside. Is this the capacitor?
3 pictures attached.
- kneebar mechanism - I have 2 of them!
- motor and attachment
- attachment interior
Many thanks.
Name:	machanism for kneebar (x2!).jpg
ID:	240601   Click image for larger version
Name:	motor and attachment.jpg
ID:	240602   Click image for larger version
Name:	attachment - capacitor?.jpg
Mgtstan is offline
Old 3rd Sep 2021, 4:40 pm   #5
Station X
Station X's Avatar
The printed label suggests the component is a dual capacitor. A clearer picture of the label would help. It looks easy enough to disconnect it rather than snip it out.
Might be worth drawing out the circuit.
Graham. Forum Moderator
Station X is offline
Old 3rd Sep 2021, 5:09 pm   #6
Nickthedentist
Nickthedentist's Avatar
That’s a triple capacitor, 80nF & 80nF & 4nF, from what I can make out from the slightly blurry photo.
Nickthedentist is offline
Old 5th Sep 2021, 4:46 pm   #7
JonSnell
JonSnell's Avatar
The triple capacitor is an interference suppressor to allow the family a view of the 405 line television without too much interference and noise.
My 99 has two capacitors in the foot pedal for exactly the same reason. One of them shorted and I was either fast or faster!
Replaced them with two 100n Class X axials.
Valve equipment repairs since 1968 https://jonsnell.co.uk
JonSnell is offline
Old 9th Sep 2021, 10:44 pm   #8
Mgtstan
Thanks everyone. I disconnected the capacitor unit, and functionality has been restored.
Mgtstan is offline
