Old 25th Jul 2021, 9:09 pm   #1
els1967
Default PVC/silicone plastic grip fluted tubing
Sorry if this isn't appropriate so delete if required.
I'm hoping someone can help. I'm after this kind of fluted/ribbed plastic/pvc/silicone tubing as per the pic. I've searched high and low but can't find any anywhere except in a biggish size, ie around 10-15mm diameter. In any case the seller had something like 100m minimum order. I really need some about 5 or 6 mm. Has anyone ever come across it?
Thanks
els1967 is offline
Old 25th Jul 2021, 11:41 pm   #2
majoconz
majoconz's Avatar
Default Re: PVC/silicone plastic grip fluted tubing
Does it have to be waterproof? I've put wires into shoe laces before now and they look pretty good. Just cut the ferrule off the end then carefully melt the end of the tube or just a quick dip into Evostik. Join all the wires together in a bit of heatshrink then they will slide easily through the shoe lace.
Cheers - Martin ZL2MC
majoconz is offline
