27th Jan 2021, 6:37 pm | #21 |
Re: 'Proper' DAB conversion for valve radios
With a pantry transmitter, you just have one channel accessible from the radio. If you want to tune around and explore other stations, the tuning control is in you pantry, on whatever is feeding audio to the little transmitter.
With the DAB converter, you can tune around and explore on the set itself. I think this will feel rather different to an observer than would having to nip off to another room to change the station. On the other hand, one pantry transmitter could be used by a variety of sets, do each set in a display could be powered up in turn and demonstrated. The German DAB converter is very clever, but it has fundamental differences with a pantry transmitter. The strengths and weaknesses don't directly compare. David
28th Jan 2021, 3:21 pm | #22 |
I think there is no 'one fits all' solution. Pantry transmitters are of course perfect for collectors who want to be able to use multiple radios.
Where a set has a PU socket, a lot of my customers like little Bluetooth receivers connected to it. I4CY's FM to AM converter is great as well. This DAB conversion provides another option and does allow you to continue to 'tune' your set. What matters most is the ability to keep our wonderful old sets working, rather than becoming expensive ornaments! |
28th Jan 2021, 3:40 pm | #23 |
I think there is room (or reason) for both a pantry transmitter and a dedicated 'DAB' valve radio. With the pantry transmitter you have to effectively power and run three pieces of equipment, but on the plus side it can be transmitted to any number of sets. With the plug in DAB device you have a stand alone, 'switch on and off' set that makes it independent of anything else. I like the sound of it (pun optional) but I'll wait for reports. If it's good I'll probably get one.
Edit: Just notice David has said something very similar.
28th Jan 2021, 8:09 pm | #24 | |
I can quite appreciate the 'tactile' appeal to some, of being able to tune DAB station by using the tuning knob on the radio and that's a point well made, but in terms of the range of listenable content, a 'pantry transmitter' can have inputs from DAB,FM, MP3 player, smartphone or whatever, so in that regard, a pantry transmitter has greater functionality. I have a mini-mod and FM/AM converter which sit alongside whichever radio I have in use, and they each perform really well. If I were minded to want to listen to DAB on an old set, I'd probably do so via a Bluetooth module, albeit that would use only the Audio stage of the radio - not the RF/IF stages, either via a changeover switch, or if present, a gram socket. As I said earlier, I'm not detracting in any way from the technical ingenuity of the 'proper' DAB device, and I understand the fascination and admiration that members have expressed. That said, I suspect that anyone other than ourselves, who may only a passing interest in seeing an old radio lit up with music coming from the speaker, will be unconcerned about the technicalities - just the functionality. Forum members who have visited National Trust premises may have often seen 1930/40s radios emitting music of same vintage as the radio, which is coming from an MP3 player concealed inside an otherwise empty cabinet. Rather ironic given the the NT is dedicated to restoration and conservation, but I guess it overcomes any safety issues that might otherwise arise. I'm always a little dispirited that when we have visitors (pre lockdown), they rarely remark or express any interest in the Ekco A22 that I restored, but are fascinated by the little 4-tube nixie clock I made that sits alongside it. Mostly, they seem more impressed with the KB FB10 'Toasters' that were scrappers which I've restored and sprayed in bright non-original colours, which they refer to as 'cute, dinky, funky or cool'.
28th Jan 2021, 8:21 pm | #25 |
The radio I currently intend to modify is an HMV 1252 FM tuner. The front end is rubbish, but the IF and demodulator work fine.
The owner, also had a lovely MW / LW / VHF Cossor table model that I restored for him, and it has a PU socket. He intends to connect this HMV unit to that in order to add DAB to an already great radio. Good idea. As I have eluded to already, different solutions for different situations. Can't wait to actually get my hands on one of these modules though and see how it performs in practice. There are a lot of DAB multiplexes in my area and it will be interesting to see how the spacing of all those stations works out! Last edited by agardiner; 28th Jan 2021 at 8:22 pm. Reason: Typo |
30th Jan 2021, 6:25 pm | #26 |
Exactly how 'plug and play' is this device? does anyone know? Looking at the photos there appears to be wires going in all directions. Is it simply a case of removing a valve and replacing it with the DAB plug in unit and leaving the trailing module hanging around in the back of the set?
1st Feb 2021, 3:24 pm | #27 |
It appears that I won't be trying it after all in this particular set.
Although the mixer tube is what is replaced, it seems that the unit is really intended for AM sets. The FM version has a shield which sits over the FM mixer and detects the oscillator frequency. The output however is then post the IF and detector stages, so audio output only. Still allows tuning normally though but pointless in this particular tuner. The AM version remains exciting though as that does actually produce an IF output. Oh well - another set will no doubt require it at some point! |
1st Feb 2021, 3:32 pm | #28 |
Call me slow, why do you want an IF output?
1st Feb 2021, 3:40 pm | #29 |
1st Feb 2021, 6:23 pm | #30 |
Hi to all,
Via reading this thread, i contacted HSE in Germany to get more info about the DAB+ converter. I received the text in the document added here (Word docx format). Seems indeed to pertain to operation with AM radios and not those with FM circuitry. Best Regards jhalphen Paris/France |
1st Feb 2021, 6:37 pm | #31 |
Great additional information. Thanks for posting.
30th Mar 2021, 12:47 pm | #32 |
So - finally hoping to order one of these to try. Will be to convert a Bush DAC90. Will report on progress and how well it works once done!
14th Apr 2021, 6:08 pm | #33 |
DAB conversion module on order!
DAC90 all restored and ready for the module. Can't wait to try it and will obviously report back here. Checked with the engineer who is building the unit; the number of stations is limited to 100, and will be confined to the MW band, so the band switch will presumably be unused. |
15th Apr 2021, 4:24 pm | #34 |
Very clever idea.
17th Apr 2021, 5:06 pm | #35 |
It's very clever but personally I would never fit a DAB or Bluetooth unit to an old radio, not even for a paying customer. It's just "wrong".... says the guy who on the other hand would have no qualms about replacing every resistor and capacitor with modern ones!
I've not seen the term "pantry transmitter" before now but that would be the way I'd do it. |
19th Apr 2021, 3:07 pm | #36 | |
19th Apr 2021, 4:57 pm | #37 | ||
19th Apr 2021, 5:24 pm | #38 |
"Do what you like, it's you radio after all", I would probably draw the line at cutting a hole in the tuning scale for an LCD but maybe not replacing it (the scale) with an e-ink one. Now there is a thought.
22nd Apr 2021, 10:36 pm | #39 |
I look forward to your findings with great interest.
All the very best, Tas |
5th May 2021, 1:25 pm | #40 |
It has arrived!
I will install and try it out over the weekend, and wright up a review next week. |
