10th Dec 2020, 9:05 pm | #21 | |
Re: Junk box low watt amp build
Here's another sound test I did today, going for the creamy overdrive of little pentodes pushed and pulled to distraction but very low volume. Albatros interpretation , Strat in-between pickup 2/3 out of phase -> small pentode pp amp -> 2x12" speakers wired in series for 16 Ohms -> Sure SM57 -> firewire audio interface -> logic pro + lot of reverb -> mp3 |
10th Dec 2020, 9:34 pm | #22 |
Doug, I'm following this thread with some interest..... If you'd like half a dozen Cinch paxolin B7G sockets and a couple of nicer mil surplus skirted ones in a Jiffy bag just PM me your address. If you fancy blowing your socks off (ish) with a heady 10W I could chuck in a couple of unbranded NOS USA 6005 (6AQ5 equiv) toobs for luck.
10th Dec 2020, 10:20 pm | #23 | |
PM sent Doug |
13th Dec 2020, 3:54 pm | #24 |
Some good progress being made...
I posted a thread on a US based guitar forum to get feedback about the tone of the EF80/EF184 low watt amp. RobRob, one of the forum member has just provided load lines for an EF80 and a full turret board layout when using the EF80 in the push pull output stage, including a readily available output transformer. The preamp and PI stages are from the Fender Bassman amp. Some say the Fender Bassman was the amp that 3 young radio hams in and around London were "inspired" by to create the famous Marshall JTM45 in 1963, others have used the word "copy". Marshall of course was just the shop owner. https://robrobinette.com/Drawing_Tub...Lines.htm#EF80 I'll try a 240 Ohm cathode resisters in-place of the 100 Ohm one I've been using. Maybe add a switch to toggle between the two. Doug |
24th Dec 2020, 9:29 pm | #25 |
The borrowed OT is back in it's amp, replaced with a mains toroidal...
I used a £10 dual 115v pri/dual 12v sec 15VA The 2 primaries are tied together 115-0-115 to give a CT. The 2 12v secondaries were easy to get at, these are wound bifilar. I unwound 120 turns and added a taps to give a ratio of 38:1 then unwound a further 60 turns to give 57:1. Amp still sounding good, no distortion seen on a 60Hz sine wave until it's over driven. Doug |
