Reply
Old 8th Jul 2021, 5:24 pm   #401
kan_turk
kan_turk's Avatar
Default Re: Baird T5 restoration project.
Great work as usual
Rgds
John
kan_turk is offline   Reply With Quote
Old 8th Jul 2021, 9:42 pm   #402
FERNSEH
FERNSEH's Avatar
Hi John,
many thanks for the compliment.
The T23 power unit was refitted today. It was allowed to operate for over two hours and was trouble free.
The modules taken from T5 which can be considered to be fully restored are: the EHT unit, the timebase and the power pack. Although proved to be working the sound and vision receiver modules still need more work, mainly detailing to restore the original appearance.
The same goes for the T23, all the sloppy servicing procedures from 1993 have been corrected and the modules now resemble as close as possible to how the set was made in 1938.
The next stage of the electronic restoration of the T5 will be the sound receiver.
This is the version with the regenerative detector.
DFWB.
FERNSEH is offline   Reply With Quote
Old 23rd Jul 2021, 9:20 pm   #403
FERNSEH
FERNSEH's Avatar
The sound receiver unit in the T5 has the original B & I make capacitors.
I've started the messy task of restuffing these components. There's two 0.02mfd capacitors and two of 0.5mfd.
DFWB.
Old 13th Oct 2021, 11:25 am   #404
FERNSEH
FERNSEH's Avatar
The Baird T5 project has restarted now that a number of important components have been found to enable completion of the electrical restoration.
The self oscillating frame timebase transformer has a winding which is employed to cancel out the anode current in the Cossor 41MP triode.
The 75Kohms high wattage carbon resistor in series with the balancer winding has gone high in value, up to 132Kohms. Two wire-wound 75K resistors were purchased from an online parts seller. The resistors will be reliable replacement for the original carbon resistors. The other resistor has been fitted in the T23.
DFWB.
ID:	243311   Click image for larger version
Old 13th Oct 2021, 8:49 pm   #405
bobhowe
bobhowe's Avatar
Hi David you are cooking on gas today kind regards Bob
Kind regards, Bob.
bobhowe is offline   Reply With Quote
Old 13th Oct 2021, 10:00 pm   #406
FERNSEH
FERNSEH's Avatar
Hi Bob, everything was going well and then the wire-wound focus potentiometer failed. Fortunately, a replacement was to hand.
These components are very expensive if you are buying new ones.
DFWB.
Old 13th Oct 2021, 10:16 pm   #407
beery
beery's Avatar
I love the brown crackle paint on the timebase control panel
beery is offline   Reply With Quote
Old 13th Oct 2021, 11:19 pm   #408
bobhowe
bobhowe's Avatar
DFWB.
Hi David lucky you had a potentiometer at hand where could you have bought it when you first started out doing TV repairs ? kind regards Bob
Kind regards, Bob.
Old 21st Oct 2021, 9:26 pm   #409
FERNSEH
FERNSEH's Avatar
Baird T5. All the BICC make capacitors in the sound receiver unit have been restuffed. Three 0.5uF and two 0.02uF.
DFWB.
Old 22nd Oct 2021, 8:42 am   #410
peter_scott
peter_scott's Avatar
Looks really good!
Peter
peter_scott is offline   Reply With Quote
Old 28th Oct 2021, 9:06 pm   #411
FERNSEH
FERNSEH's Avatar
The frame of the lower cabinet back was reassembled today.
Diagonal measurements spot on, 31 7/8".
DFWB.
Old 14th Nov 2021, 5:37 pm   #412
FERNSEH
FERNSEH's Avatar
For the Baird T23 sound receiver unit many of the capacitors fitted in the 1990s have been replaced with types having a more convincing appearance. Found one BICC capacitor.
The small 0.02mfd capacitor was originally made by NSF in the UK.
Now I have to restore both sound receiver units to working order.
DFWB.
Old 27th Nov 2021, 11:58 am   #413
FERNSEH
FERNSEH's Avatar
New loudspeaker baffle fabric is needed to replace the worn out material.
A similar fabric is used on the T23.
DFWB.
ID:	246741   Click image for larger version
Old 28th Nov 2021, 10:19 am   #414
peter_scott
This thing is going to be fabulous!
Peter
Old 28th Nov 2021, 6:01 pm   #415
FERNSEH
FERNSEH's Avatar
Hi Peter,
many thanks again for those words of encouragement.
The search is on for the correct pattern of loudspeaker fabric.
The last cabinet parts which will have be made are the three bars across the loudspeaker baffle. The outer bars are in good condition but three others fell victim to the woodworm invasion.
DFWB.
Old 7th Aug 2022, 4:40 pm   #416
FERNSEH
FERNSEH's Avatar
Default Baird T5 restoration project.
Work has restarted on the final stages of the restoration job. The lack of certain key items was holding up the restoration. One of the most difficult items to source was the correct pattern fabric for the loudspeaker. As luck would have it a good friend has a roll of cloth which was bought in the USA. It's unlikely a better match for the original material will ever be found.
A piece of the material has been donated for the project.
Now the restoration is moving on again.
The pictures were taken a month ago.
DFWB.
ID:	262365   Click image for larger version
ID:	262366   Click image for larger version
Old 7th Aug 2022, 5:00 pm   #417
peter_scott
Excellent match!
Peter
Old 9th Aug 2022, 11:01 am   #418
FERNSEH
FERNSEH's Avatar
The position of the chassis attachment holes on the newly made shelf must be determined. That done however, to find the exact positions of the holes it still might still be a better idea to remove the shelf from the T23.
Goes to show even way back in 1935 ease of of servicing of these early Baird TV receivers was given consideration by the designers.
DFWB.
ID:	262498   Click image for larger version
Old 10th Aug 2022, 9:27 am   #419
Heatercathodeshort
Heatercathodeshort's Avatar
That speaker cloth looks ideal David. I simply can't believe the hours you have spent restoring this Baird T5. John.
Heatercathodeshort is offline   Reply With Quote
Old 11th Aug 2022, 1:54 pm   #420
beery
beery's Avatar
Great to see you back on it David.
It can be hard to keep up momentum with these long jobs, especially when missing parts cause hold ups. I'm struggling to keep up with the two pre-war restorations that I'm currently doing.
Andy
Reply
