22nd Oct 2021, 8:07 am | #1 |
Radiogram Wiring Diagram. BSR Deck.
Hi, I have been asked to look at a,
Vintage Valve Radiogram Monarch BSR Model B55 TAG Radio &. From my inital look, some of the wires are missing or broken.Does anyone know where I can get a wiring diagram for this model or any suggestions. Thanks for an help Eddie |
22nd Oct 2021, 9:26 am | #2 |
Re: Wiring Diagram
BSR Monarch xxxxx is just the record player deck, it doesn't help to identify the actual radiogram make and model. This would normally be marked on the rear panel or perhaps the radio/amplifier chassis itself. A few clear pictures may also help.
Unfortunately, if the set was manufactured in the RoI, service information may be hard to find......
22nd Oct 2021, 10:21 am | #3 |
Re: Radiogram Wiring Diagram. BSR Deck.
As a complete excercise in lateral thinking could it be the Radiogram version of this :
https://www.radiomuseum.org/r/banner_b55.html Banner in RM show a model B55TAG If so the Chassis is likely to be the same as the Sobell 515 Cheers Mike T
22nd Oct 2021, 10:31 am | #4 |
25th Oct 2021, 11:11 am | #5 |
Thanks for all your help, I now think the info. I supplied is not correct, so I am attaching some pictures in a hope of identifying it. The radiogram is in a friends house, so progress is slow, I just want to see if it's worth fixing.
Any suggestions/help appreciated, Thanks, Eddie |
