Old 9th Feb 2020, 5:32 pm   #1
MrBungle
MrBungle's Avatar
Default Repairing HP moving coil meter "peeling"
Does anyone know a good approach for repairing the peeling meter faces on HP moving coil meters? I bought an HP 3400A today which needs some work doing on it. It hasn't lost much if any of the legend so I'd like to try and prevent it from getting worse.
MrBungle is offline
Old 9th Feb 2020, 6:19 pm   #2
Electronpusher0
Default Re: Repairing HP moving coil meter "peeling"
I had the same problem with an HP distortion meter. I took the scale off the meter and scanned it. I then imported it into Libre office draw and drew a replacement on another layer above, deleted the imported pdf layer, printed it and stuck the print onto the scale after rubbing off as much of the peeling layer as I could.
A tip when using Libre office Draw, it imports pdf drawings as editable segments which is very powerful if you want to move or delete sections but when using the pdf as a template select the whole drawing and group it, then protect the group against editing.
Peter
Electronpusher0 is offline
Old 9th Feb 2020, 6:26 pm   #3
ajgriff
ajgriff's Avatar
Trouble is if you try to flatten the curly bits before fixing with clear lacquer you'll probably end up with more of a mess than you started with, at least that's what would happen if I tried it! I agree with Peter in that the best solution is to make a reproduction using the software tools now available to us.
Alan
ajgriff is offline
Old 9th Feb 2020, 6:27 pm   #4
The Philpott
The Philpott's Avatar
I managed to stabilise some flaking paint on an old scale plate (however it had not curled up as such) using a clear acrylic lacquer automotive touch-up pen. Some of these lacquers dry very quickly though.
(crossed with Alan's response)
Dave
The Philpott is online now
Old 9th Feb 2020, 7:17 pm   #5
MrBungle
MrBungle's Avatar
Thanks all. I’ll look into these approaches
MrBungle is offline
Old 9th Feb 2020, 8:12 pm   #6
FIXITNOW
FIXITNOW's Avatar
I tend to mist them with an aerosol can of lacquer, a few thin mist coats to set it in place.
FIXITNOW is online now
Old 11th Feb 2020, 8:16 pm   #7
factory
Another possible method here;
https://www.vintage-radio.net/forum/...0&postcount=48
factory is offline
