11th Jul 2011, 1:59 pm | #61 |
Re: Rebuilt MW22-7 Tube in Bush TV1
Too high an EHT?
11th Jul 2011, 4:25 pm | #62 |
Wouldn't the picture be too small in that case?
6.3v on my heaters is no longer enough to get me going in the morning!! |
11th Jul 2011, 5:17 pm | #63 |
There is often a large variation of adjustment possible. Also beam current sets the deflection power needed. It's possible to have higher speed electrons due to excessive EHT, yet reasonable beam current due to bias of other anode(s), grid and Cathode. Though I'm not familar with tube. If brightness or A1 (if exists) has to be very low, suspect high EHT which can affect phosphor.
11th Jul 2011, 5:38 pm | #64 |
I think you mean acceleration voltage. On a magnetically deflected CRT the deflection field required is proportional to the square root of the acceleration voltage. If it was proportional to current then light and dark parts of the picture would have different deflection sensitivity.
11th Jul 2011, 6:35 pm | #65 |
Hi Chaps
Thanks for your comments. I don't believe that the EHT is to high. This tube is rated to work at 10 kV and that is what I have measured it at. In fact at lower EHT the effect appears worse, but this is only because higher EHT gives a brighter picture which tends to mask the effect more. The tube is a triode. Frank |
11th Jul 2011, 7:06 pm | #66 |
I don't believe for one minute that the EHT voltage has anything to do with the long persistence effects with your particular tube. The MW22-7 in it's original form is rated at a maximum of 7kv on it's final anode but as 98% of these tubes were operated from a mains derived EHT system it would rarely be more than 5.5kv. Add the aluminising and I would say that 7kv would be more than enough to give a bright picture on a 9" tube. The aluminised Mazda CRM93 in the TMB272 runs at 9kv maximum.
I don't know of any domestic 9" receiver that runs at 10kv. The Bush TV1 struggles at 5kv. All television tubes have to have a short to medium persistence phosphor and I think this one has a bit to much of the twinkle dust that produces the longer persistence. I don't think it's any more serious than that. Regards, John. |
11th Jul 2011, 7:13 pm | #67 |
I don't really believe it either. A Straw clutching. But it's true that strange things can happen with too high EHT.
You're probably correct. |
11th Jul 2011, 7:16 pm | #68 | |
11th Jul 2011, 7:27 pm | #69 |
Sorry I didn't make it clear in my postings.
This is the Mullard MW31/74 tube that I got fitted with a Mazda CRM123 type gun. Frank |
11th Jul 2011, 8:42 pm | #70 |
Thanks Frank, that makes more sense. The MW31-74 is a brilliant tube with a true black and white picture. It would require 10kv when aluminised similar to the Brimar/Cintel C12B. J.
11th Jul 2011, 9:04 pm | #71 |
The dual-colour phosphor system, as we are guessing is at work here, was developed as an anti jamming measure in WW2. The blue short phosphor excites the yellow-green long phosphor and the blue image is then optically filtered out for the viewer. This causes locked images from aircraft returns to appear much brighter than unlocked or transient jamming noise.
source: Dick Barrett's The Radar Pages
Kevin |
15th Jul 2011, 6:35 pm | #72 |
I received a phone call from Jerome today, we had a very enjoyable conversation about many things vintage, time just flew by and I am afraid I must have raised his phone bill considerably.
He explained to me that at the moment due to there recent bereavement the RAEDERSDORFF brothers were tied up, which is very understandable. Jerome has found out that they do not mix the P4, they get it from a UK based firm. I was told the name of it but just cant remember it now. He is hoping to have more information next week. I will post updates as things develop Frank |
15th Jul 2011, 6:51 pm | #73 |
Good Day Gentlemen,
I had a long talk today with both Frank C. in Ireland and RACS, Southern France. 1) Frank's Long persistence P4 CRT video display pictures cannot be explained. The CRT was tested, and are all are post-rebuild CRTs, with X-Y raster and video content and all seemed OK. RACS absolutely wants to have satisfied customers, so the sent to be rebuilt CRT will be rebuilt for the usual cost (+ shipping cost & insurance fees) if the customer wishes so. Best Regards jhalphen Paris/France Last edited by jhalphen; 15th Jul 2011 at 7:16 pm. |
16th Jul 2011, 8:51 am | #74 |
The title of this thread is now misleading as the current posts refer to a different tube and a different phenomenon.
The response from RACS as reported by jhalphen is rather disappointing as it does not help to explain the problem experienced by Frank C or make clear the terms of RACS offer of rectification. |
16th Jul 2011, 9:15 am | #75 | |
I know this is off topic now, but surely this problem should be repaired free of charge or at least at considerably reduced charge, The cost of repairing these CRT's is not cheap in the first instance, I saw this tube not long after it was returned to Frank and the problem was seen by a few forum members at the time. I can understand that Frank will have to pay the carriage both ways, RACS though should make a better offer to be honest!
Cheers, Trevor. MM0KJJ. RSGB, GQRP, WACRAL, K&LARC. Member Last edited by Brian R Pateman; 16th Jul 2011 at 11:24 am. Reason: Quote fixed. |
16th Jul 2011, 10:17 am | #76 |
Hi Chaps
Yesterday while talking to Jerome the impression that I got was quite different from the one reflected in his post above. Maybe I misinterpreted what he was telling me I don't know. As far as I understood he had to talk to RACS again. I'd be surprised if RACS didn't at least want to inspect the tube Maybe Jerome can clarify things a little? Frank |
16th Jul 2011, 10:33 am | #77 |
I wonder if something has been lost in translation here. While Jerome is totally bilingual French/English it's always possible that something has slipped.
16th Jul 2011, 11:04 am | #78 |
Maybe he means at no cost except the post and insurance ?
My pre war tube is to go there soon , so Im hoping that will run smoothly !!! |
16th Jul 2011, 12:39 pm | #79 |
Yes I do hope so, perhaps it's a simple Typo or too many glasses of French wine
16th Jul 2011, 1:09 pm | #80 |
Yes it was rather a vague statement. I'm quite sure this will be sorted to everyone's satisfaction. J.
