Old 2nd Nov 2019, 11:15 pm   #261
john_newcombe
Default Re: Gemini 80-Bus System
Ok, but just so I am clear, when should I do this? before or after the select?
Code:
	.Z80
	ASEG
	ORG 0100H
	.PHASE 0100H
.1797	EQU	0E0H		;Base address
WCTRL	EQU	.1797+5		;SASI (Winchester) control/status port
WDATA	EQU	.1797+6		;SASI (Winchester) Data port
TEST:
	LD	A,0FEh		; set Data 0 here ???
	OUT	(WDATA),A	;
	LD	A,5
	OUT	(WCTRL),A	; set the -SEL
	IN	A,(WCTRL)	; read status
	JR	TEST		; loop
john_newcombe is offline
Old 2nd Nov 2019, 11:26 pm   #262
john_newcombe
Originally Posted by JohnBHanson View Post
I have a GM849A circuit diagram - but too large to post here.
Would be possible to email it to me? I have just sent a PM with my email address.
Old 2nd Nov 2019, 11:54 pm   #263
JohnBHanson
The code above looks ok - you set d0 and then issue the sel command. On a GM849A you will have to then output 7 to restore the control lines inactive however this is not required with the previous versions of the SCSI interface as sel is only active for the duration of the IO write cycle.
JohnBHanson is offline
Old 3rd Nov 2019, 9:54 am   #264
john_newcombe
Thank you for sending the circuit diagram, I have now added this to the resource page on https://glasstty.com/wiki/index.php/...0-Bus_Resource.
Old 4th Nov 2019, 7:12 pm   #265
john_newcombe
No luck with the SASI/SCSI yet, I will experiment with latching the select and see how I get on.
As an aside, I found a Teac 55F in a pile of rubbish some guy was clearing out. I cleaned it up attached it as B: and knocked up some code to copy the system track from A: (Gotek) to B:. I swapped the drives over and I am now booting to the floppy with the Gotek as B: It suddenly seems far more vintage. .
Old 5th Dec 2019, 8:59 pm   #266
john_newcombe
Whilst working to add Winchester support to my system it started to become clear that I would need to modify my GM829 Floppy/SASI implementation in order to latch the select line in a similar way to the GM849 in order for it to work with a modern SCSI disk or SCSI disk emulator e.g. the SCSI2SD. I was contemplating fitting a small board to achieve this when I received a message and then a phone call from Charles O'Brien who was, at the time, based Blunsdon Swindon. He has now moved to Hunmanby, East Yorkshire.
Thanks to the generosity of Charles, I am now the proud owner of a Gemini GM916 Galaxy MFB. The unit includes 5.25", 8" and 3.5" disk drives and a Winchester disk. The machine had been owned from new by Charles and had been used when he ran a consultancy business called Obsys Ltd.
I have opened the various boxes and discovered the following;
  • GM813 CPU and Memory board
  • GM832 SVC Video Controller
  • GM849 Floppy/SASI Controller (Modified for MFB)
  • An 8 inch double sided drive
  • Teac FD55 48tpi 5.25 inch Drive
  • Teac FD55 96tpi 5.25 inch Drive
  • 3.5 inch drive
  • Rodime 201 5Mb Winchester Disk
  • GM827 Keyboard
  • Gemini Monitor
The machine isn't working at the moment but once I get a little time I will start the diagnosis.
I feel very lucky to have the opportunity to preserve this machine, naturally, if there is interest, will keep this thread going and continue the 80-Bus saga on http://glasstty.com.
Old 5th Dec 2019, 10:01 pm   #267
JohnBHanson
I would appreciate knowing what the modifications are to the GM849 to support the MFB as I would like to include a modified version as an option with my xbeaver emulator.
Many thanks.
Old 5th Dec 2019, 10:59 pm   #268
john_newcombe
I thought you would. It will be at least a week until I get time to investigate but will sort out decent photographs and details of anything I find. I have not removed the board yet but I can see that it has a sticker on it that says 'MFB Only'.
Old 6th Dec 2019, 8:35 pm   #269
JohnBHanson
To help out - differences appear to be on the input port 0e5 bits 5 and 6. This is handled by IC2.
On the standard GM849A this is determined by IC14 from the outputs of port E5 bits 3,4,5,6,7 which come from IC19
According to the GM849A circuit IC14 is an 74LS21 but the circuit diagram has unused
pins of IC14 wired to the some of the outputs of IC19
I suspect that IC14 is a different chip on the MFB version of the board or there are some board patches in this area.
Looking at the youtube video of the tear down the board is a GM849 and not a GM849A but I cannot see if there has been any changes in the above area.
As this is in the SCSI area I am wondering if this is an attempt at protecting the MFB from being run on normal gemini machines.
I look forward to any additional info you can provide in due course.
Old 6th Dec 2019, 9:32 pm   #270
john_newcombe
This probably won't help much but here is a photo of the card taken from the MFB.
https://glasstty.com/wiki/images/0/0f/GM849.jpg
Old 7th Dec 2019, 12:40 am   #271
JohnBHanson
Thanks - that is wonderful - confirms my suspicions IC14 has the last two digits removed from the device type - but confirms this is a 74LS series. Interesting,
When you get a running system - even your old system with RP/M and this floppy card would you be kind enough to run this mbasic program and send me the output.
Thank you...
10 FOR I=0 TO 255 STEP 8
20 OUT &HE5,I+7
30 P=INP(&HE5)
40 PRINT HEX$(I+7),HEX$(P)
50 NEXT I
many thanks....
Old 7th Dec 2019, 9:57 am   #272
qazxsw123
Also from the same site
https://glasstty.com/wiki/index.php/...49A_Manual.pdf
https://glasstty.com/wiki/index.php/...9A_Circuit.pdf
qazxsw123 is offline
Old 7th Dec 2019, 10:20 am   #273
JohnBHanson
Just to clarify I am talking about a different floppy controller - not the same as a GM849/GM849A. This different floppy controller has a different IC in position IC14 which is not a 74LS21 as shown on the circuit diagram you quote.
Old 7th Dec 2019, 2:13 pm   #274
john_newcombe
Thank you...
20 OUT &HE5,I+7
30 P=INP(&HE5)
50 NEXT I
many thanks....
Of course... and thanks for the boost in confidence in assuming I will get it working!
Old 7th Dec 2019, 2:46 pm   #275
john_newcombe
I have some documentation that may shed some light on the GM849 changes.
The previous owner of this machine bought it from new and had an annual support contract for some years. During that time (Oct 1986) the machine was returned for modifications.
I also have an un-dated letter that suggests that one of the updates included a 'new' disk controller, although it does not mention any details. The new controller was apparently changed to allow for many 'non-standard' disk formats to be supported, e.g. 'U' format, unconventional side fields, reverse sides, either physical or logical non-standard sector lengths, logical skewing on both sides of the disk, deleted data marks.
The un-dated letter also suggests that this new controller allowed for 4 external floppy disks and user configurable Winchester partitioning with an alternative OS on track 1 and refers to the previous system as MFB 1. As I also have an MFB 2 software manual I am wondering if the modified GM849 is the 'new' controller mentioned.
Old 8th Dec 2019, 3:26 am   #276
JohnBHanson
My guess would be that from what you say MFB1 was based on a GM829 floppy disk controller or a variant of. The upgrade was probably to GM849 controller with custom IC14 for copy protection.
I have a pdf for the gemini catalog No5. This does not list the GM849 controller but does
list the GM829 controller. It also lists the Multi Format System as a GM916 or GM921 depending on hard disk size of 5.4 or 16.5MByte. From what I have heard from you the MFB2 system is based on the GM849 modified floppy disk controller and has number GM925.
Maybe some of the documentation will through some light on the history. I am looking forward to reading the MFB manuals if you manage to scan them.
PS - Work is proceeding well on modifications to run the MFB system under xbeaver emulation.
Old 8th Dec 2019, 4:55 am   #277
john_newcombe
The system I have is marked as a GM916 and it is now my belief that it was upgraded to the MFB2 spec to bring it in line with the later GM925 just as you suggest. It is in the cream metal Galaxy cabinet and includes the GM827 keyboard (although that is also marked as GM916).
I will be able to start scanning the manuals next week.
Old 8th Dec 2019, 10:20 am   #278
john_newcombe
Just had time to do a quick scan of the MFB 2 Software Manual with my phone. I will do a better one when I get chance, but thought you might like an early view.
https://glasstty.com/wiki/index.php/...are_Manual.pdf
Old 8th Dec 2019, 4:14 pm   #279
JohnBHanson
Thanks for the manual - timing just right as I had got the MFB system booting...
Just a warning - the GEMQDDS definition used in the MFB system is not the same as previous QDDS format used by you on your rack system. The side mode is different - one is "C" and the other is "S".
Please check this before you use your MFB system to transfer data between systems.
PS - thanks for the file it was interesting I have MFB now booting from hard disk.
A few tweeks still needed to finalize including the results of the basic program given above in post 274.
I will let you know when it is complete
Old 8th Dec 2019, 5:28 pm   #280
john_newcombe
That is great news, looking forward to seeing it in action. In terms of the QDDS format being different, is this simply because I opted from the wrong side mode in the first place? All my disk images and zip file creation are scripted so i can easily fix and re-publish.
