Old 2nd Oct 2018, 8:34 am   #61
KeithsTV
KeithsTV's Avatar
Default Re: FM stereo
I remember the quadrophonic broadcast which I think was in 1974. I took my tuner, amp and speakers round to a friends house for the test. I can't remember much about the content of the programme but I think at one point the sound "moved" diagonally.
I wonder if a copy of the broadcast still exists?
Keith
KeithsTV is offline
Old 2nd Oct 2018, 10:42 am   #62
red16v
Originally Posted by Dai Corner View Post
I may be imagining this, but didn't they try experimental quadrophonic broadcasts using two of the stereo networks some time in the 1970s?
I thought I remembered that, I had it in mind that the BBC broadcast The Who's 'Quadraphenia' but Googling reveals nothing to back that memory up.
I built a Heathkit tuner amp in the early days of stereo, and noted that the de-emphasis components supplied were for the American specification (50us instead of 75uS? - I can't remember after all this time). I wrote to Heathkit UK about it and they not only thanked me for pointing out the error they also sent me the correct R&C components in a small plastic bag to correct my own model.
red16v is offline
Old 2nd Oct 2018, 11:09 am   #63
Nuvistor
Nuvistor's Avatar
Quadraphonic sound, we got a couple of units but had to virtually give them away, not a lot of interest from the customers we had. I don’t remember the makes but they were Japanese units, the equipment was decent quality.
Others may have sold lots but not in the shop I worked at.
Frank
Nuvistor is offline
Old 2nd Oct 2018, 3:03 pm   #64
John10b
I remember having to study the Foster-Sealy discriminator in my C&G exams way back in time ( 1960 - 1970 ish or was it later? ).
John
John10b is offline
Old 2nd Oct 2018, 3:12 pm   #65
ms660
ms660's Avatar
Me too, in the late 1960's at Stockport College.
Lawrence.
ms660 is offline
Old 2nd Oct 2018, 3:33 pm   #66
Alvin
Alvin's Avatar
I remember it well - the upstairs flat brought their stereo down to us and 4 or 5 of us sat huddled tightly together as close as possible to the centre of the 4 speakers - I don't recall the programme content and I can't say we were overly enthralled at the novelty.
According to Genome it was on July 6th 1974
https://genome.ch.bbc.co.uk/5c91d7ea...a8f9f158bb044d
Alvin
Alvin is offline
Old 2nd Oct 2018, 9:10 pm   #67
Ted Kendall
Interesting that the producer was Raymond Raikes, who had produced the first stereo dramas for the two-transmitter tests some fifteen years before.
Ted Kendall is offline
Old 3rd Oct 2018, 9:35 am   #68
Restoration73
Restoration73's Avatar
After the twin transmitter quadraphonic broadcasts were abandoned, encoded quad based on ambisonics was tried, not using proprietary SQ or QS formats but their own standard known as Matrix-H, although I don't remember when these ended. There may be a decoder design somewhere.
Restoration73 is offline
Old 3rd Oct 2018, 11:41 am   #69
Ted Kendall
Matrix H!
This had little to do with Ambisonics, which was a comprehensive system capable of encoding height information, and led to developments such as the Soundfield microphone.
Matrix H was an attempt to combine the least worst features of SQ, QS and Regular Matrix. Chief tweak was the application of a phase shift on centre-front signals, which was played about with over time, but ended up somewhere around 30 degrees. I have some tapes of Matrix H transmissions, which to be frank I haven't listened to closely, but the consensus at the time was that the clarity of the stereo picture was affected, and when I asked Tony Askew, who balanced Proms with it, his reaction was basically " awful thing - waste of time!"
If I remember right, Matrix H staggered on through a couple of Prom seasons and was then quietly interred, along with the rest of Matrix quadrophony.
Old 3rd Oct 2018, 10:29 pm   #70
kirstyd
i have this hacker RG200 bought by my parents back in 1968 that has a decoder fitted [as an optional extra]and the stereo beacon although i have never known it to work .There is some mention of stereo broadcasting in the user manual
ID:	170311   Click image for larger version
ID:	170312   Click image for larger version
ID:	170313   Click image for larger version
kirstyd is offline
Old 3rd Oct 2018, 11:52 pm   #71
Ted Kendall
That's interesting - is it connected to a roof aerial? It may just be a matter of signal strength.
Old 3rd Oct 2018, 11:55 pm   #72
Synchrodyne
It’s interesting to compare the UK and US situations, as the US also had a period of twin-transmitter stereo broadcasts before the Zenith-GE system was adopted in 1961. In that case, the norm was to use an FM transmitter for one channel and an AM (MF) transmitter for the other, as indicated in this Wireless World 1958 December item:
Name:	ex WW 195812 p.575 US Stereo Broadcasting.png
ID:	170320Click image for larger version
Name:	WW 195812 p.575 US Stereo Broadcasting.jpg
The US hi-fi equipment makers developed and offered appropriate equipment, as well. Typical was an AM-FM tuner that had completely separate, and separately tunable AM and FM sections so that they could be used in parallel for stereo broadcasts. Usually the AM section was of the wideband, hi-fi type, and a multiplex signal output allowed the FM side to work with future FM multiplex decoders. Also, some makers also offered multiplex decoders for use with the early experimental multiplex broadcasts. These I think were mostly using the Crosby FM-FM system, which predated most of the other contenders. Such units would have become redundant once the Zenith-GE system was adopted, whereas the AM-FM tuners had ongoing utility even if their combined stereo function was no longer required.
I also recall seeing somewhere that one of setmakers offered a matching pair of table radio receivers, one AM only and the other FM only, for use with stereo broadcasts. But I can’t now trace it, so it is unconfirmed. (It might have been in a magazine like Popular Mechanics).
In the UK the more limited scope of the experimental twin-transmitter stereo broadcasts would have made it harder to justify the development of specific receiving equipment. Still, for hi-fi applications, the Jason JTV FM & TV Sound tuner, which dated from mid-1958, provided a means of accessing the TV sound channel in a high quality way, that being its primary mission. (I don’t think that Jason mentioned the two-transmitter stereo application in any of its literature. The following JTV2 of late 1959 did have a multiplex output, though.) Lowther catalogued a couple of FM & TV Sound tuners circa 1960, but evidently these did not make it into production. One was said to have “double drive”, although whether this meant that it could simultaneously receive an FM and a TV sound broadcast is unknown. Two valved VHF receiving chains operating in parallel inside a small box would seem to create great opportunity for mutual interference.
As in the US, from the late 1950s multiplex outputs were incorporated in British FM tuners. Probably with the export market in mind, Quad arranged the switching in its 22 stereo control unit of 1959 to allow separate FM and AM tuners to be used independently or as a stereo pair. Or a third tuner could be used to form a stereo pair with the first, or a multiplex unit could be used with the FM tuner.
Another interesting case was Japan, where two transmitter AM-AM stereo was used for a few years before FM multiplex was adopted. The industry produced hi-fi units incorporating two AM tuners, which evidently had different IFs to avoid mutual interference. Also mirror-image pairs of AM table receivers were available. See: http://www.japanradiomuseum.jp/FMstereo-e.html. A close look at the National SA-32 tuner-amplifier illustrated therein shows that it had two AM tuners. The left-hand one also had an SW band, whereas the right-hand one looks to have been MW only. I’d hazard a guess that the left-hand unit had the standard 455 kHz IF, whilst the right-hand unit had a lower number, perhaps 260 or 110 kHz. I think some care would have been needed to obtain similar overall bandpasses.
Cheers,
Synchrodyne is offline
Old 4th Oct 2018, 12:01 am   #73
Ted Kendall
In a Sounds Good programme around 1975, Angus McKenzie spoke about being so impressed with the stereo experiments that he bought himself a TV sound tuner on the strength of it. I imagine this would have been a Jason.
Old 4th Oct 2018, 12:11 am   #74
Synchrodyne
Yes, a Matrix H decoder was described in Wireless World 1977 June, p.34ff.
This was effectively - although probably not formally - part of a series in WW through the 1970s. The attached spreadsheet provides a partial list of these articles and related items.
Cheers,
Old 4th Oct 2018, 12:16 am   #75
Synchrodyne
Probably, as Jason was the only UK maker of TV sound tuners from 1958 until it folded around 1966-67. From 1971 both Lowther and Motion Electronics offered TV sound tuners, both solid state. The Lowther model was UHF/FM only, whilst the Motion Electronics model was UHF and/or VHF and AM/FM.
Cheers,
Old 4th Oct 2018, 1:24 am   #76
fetteler
fetteler's Avatar
Originally Posted by rambo1152 View Post
Originally Posted by Brigham View Post
That was the 'buzz' word at the time, 'beacon'.
All other indicator lights were just 'lights', but the Stereo indicator was a 'Beacon'.
I think it must have been, there was a subconscious urge to use that particular word.
Can anyone else recall "stereo beacon"?
https://www.vintage-radio.net/forum/...ad.php?t=74092
Yeah, I remember the idea of a stereo "beacon", in fact I remember using a (then quite exotic) red led for just thet purpose in a stereo tuner I built in 1973. One of the first things I listened to was John Peel's show and I recall him playing the whole of Dark side of the Moon. Superb.
Steve.
Those who lack imagination cannot imagine what is lacking...
fetteler is online now
Old 4th Oct 2018, 7:31 pm   #77
kirstyd
It was connected to a roof Ariel when it was at my parents house but i dont ever remember hearing stereo radio on it .Sometimes when tuning along the scale the red light flickers but its very faint.As you say it may just need a good Ariel [it wont be helped by the fact that my house has a steel frame]
kirstyd is offline
Old 4th Oct 2018, 9:59 pm   #78
Restoration73
Non-PLL decoder beacons could light up on a mono broadcast if a 23kHz tone was present.
I assume this was transmitted for an engineering purpose.
Old 6th Oct 2018, 3:40 pm   #79
Ted Kendall
A note on one of the BBC's encoders describes the provision for inserting external 23khz in the absence of pilot tone "for transmitter signalling". Most stereo lights fire on interstation noise, too.
Old 6th Oct 2018, 4:55 pm   #80
Nymrod121
Nymrod121's Avatar
Yes - my post (#34) refers.
For what it's worth ... according to my copy of "BBC Designs Department Handbook No. 6.173 (79): CD2/11 Stereo Coder and PA20/17 Interface Unit", if the unit was manually selected to mono, the 23kHz pilot level (when internally generated) was 60mV into 75 ohms, compared to 90mV into 75 ohms when in 19kHz (stereo) mode. I'll see if I have/can dig out the corresponding DDHB* for the CD2L/4 which was the earlier ("book-case"-style) unit.
* found it - DDHB No. 6.179 (80) - yes, the CD2L/4 did the same i.e. 19kHz @ 90mV, 23kHz @ 60mV
Guy
"What a depressingly stupid machine." [Marvin: HHGTTG]
Nymrod121 is offline
