9th Jun 2017, 6:13 pm | #81 |
Re: Museum of failure.
The Concorde crashed because it ran over a metal strip which fell off a recently departed DC10. Now there WAS a failure.
9th Jun 2017, 6:14 pm | #82 |
Much improved and refined, I trust? Not too many in motor cars though.
Regds, Russell W. B. G4YLI. |
9th Jun 2017, 6:15 pm | #83 |
9th Jun 2017, 6:17 pm | #84 | |
[Both DUGA-3 and PAVE-PAWS were, in their time, spectacular annoyances to us weak-signal amateur types] |
9th Jun 2017, 6:19 pm | #85 |
I don't see the motor industry rushing to fit them in their products. Perhaps there are other issues - stigma, even - that preclude their use for more tor cars?
9th Jun 2017, 6:21 pm | #86 |
9th Jun 2017, 6:23 pm | #87 |
Can I lob the Bristol Brabazon into the mix ?
Big, slow, expensive - nascent Jet technology made it obsolete before it ever flew. Alas the DH Comet spectacularly sullied the reputation of fast-and-clean UK civil aviation and so the world bought Boeing/Lockheed. [Sidenote: I'm always intruigued at how Neville Shute Norway's "No Highway" novel anticipated by some years the Comet's catastrophic metal-fatigue issues. I consider Shute to be one of the overlooked 'visionaries' of the late-1940s] |
9th Jun 2017, 6:52 pm | #88 | |
I was paid a (then) high-end PC graphics card for the project. But it says something that even then, the only part of the system the owner felt he had a use for was the remote. |
9th Jun 2017, 7:04 pm | #89 |
The Wankel engine was a success, it did what it was meant to do and did it well. Smooth, excellent power-to-weight ratio. The rotor seals were a weak point, but when the right materials came along, life increased vastly. They're not used in cars because they burn too much oil so can't meet emission standards. Basically, they have niche applications.
If the Bristol Brabzon was a failure then what about the Hughes H4 Hercules? Even bigger, late, only one built ever, although as it did fly (once) it could be argued it was a technical success but a commercial failure! |
9th Jun 2017, 7:06 pm | #90 |
Companies are very coy about their failures - for obvious reasons. Few of them end up like the Sinclair C5 - a very public failure. The only way the public will get to know about them is if the people on the job come clean and reveal what happened.
So I trawled my own professional experience to recall what went wrong. THe first project I was on as a graduate design engineer was at Pye Telecom in Cambridge - at their mobile radio lab. I was on a team tasked with designing a version of their M206, which was an AM boot mount transceiver with a very high performance. The requirement was to meet Home Office specifications for the police and fire services. That meant covering two 4MHz wide bands - as far as I recall that was 80-84MHz and 98 - 102MHz (one band was transmit and the other receive, I can't remember which). Our version converted that to use frequency synthesis, offer both AM and FM modes, and 12.5 and 25kHz channelling. It was even clever enough to do "quasi-sync" mode without an actual IF filter wide enough to cope with three carriers spaced at 6.25kHz intervals. It had a microprocessor which scanned around very quickly to pick the best of the three carriers - and that was "clever" at the time that the MOD slapped a restriction notice on it in response to our patent application. That set failed. Not because it didn't meet the spec. Prototypes went to the HO, and as far as I know they were happy with them. They just failed to place an order. In the end there was no order, because they moved the frequency band up to around 150MHz to clear out FM Band II for the new broadcasting services. Calling it a failure may be a bit harsh, since much of the technology went back into other Pye Telecom products, notably the frequency synthesiser, which ended up in the M290 series of commercial products. Richard |
9th Jun 2017, 7:13 pm | #91 |
Another total failure that I was somewhat associated with was Ionica. This was a company based in Cambridge around 1990 - 1996. It aimed to compete directly with BT by rolling out a microwave "last mile" telephone system, which would offer customers two phone lines at less cost than BT were offering at the time. This was a point to multi-point network operating at 3.5GHz. Technically it was very advanced - no other high volume product was operating much above 2.4GHz as far as I know back then, and pushing electronics that extra GHz while keeping the costs down was a severe challenge.
The two line customer premises equipment meant (back then) that people could use their phone line for voice calls, and be on the internet with the other line - using the usual voice band modem which was the only solution at the time. Ionica went bankrupt. Not sure exactly why - probably because their business model was unrealistic, and they were possibly too disorganised to actually do a rollout in an advance economy like the UK. They had much more success overseas, in 3rd world countries - and I was involved with their partner company Nortel, which sold and installed the products exclusively outside the UK. So places like Sri Lanka and Mexico lapped up the product to the tune of millions of lines. Commonly in these sort of countries the incumbent phone supplier would take an order for a new phone line, and if you were lucky you might actually get the line 10 years later! No wonder, a line which could be provided within 2 - 3 weeks of order was an absolute winner. Total failure in the UK though! Richard |
9th Jun 2017, 7:18 pm | #92 |
Veering off the subject but there's the rolls royce vulture aero engine, the twenty-four cylinder unit is one of their few engineering failures, out of it's demise and the avro Manchester bomber it was fitted to came the legendary Lancaster.
9th Jun 2017, 7:32 pm | #93 |
That should, of course, say motor cars. I'm tempted to nominate the well-meaning but way-too-clever spillchucker 'I'll-put-in-what-I-think-he-means' mechanism in the iPhone!
9th Jun 2017, 7:33 pm | #94 |
Well Mazda used them in very successful production cars until 2013 (RX8) and are apparently still keen to develop the technology further. They are talking about and indeed building prototypes of hybrids using rotary engines.
Regards, John. |
9th Jun 2017, 7:48 pm | #95 |
WorldSpace Radio and (potentially) DAB. Trim Jeans. The Milnes gas-powered HT eliminator. The side-contact valve base. The RCA Nuvistor.
9th Jun 2017, 7:48 pm | #96 | |
From what I remember of the format-wars in the late-70s/early-80s what truly stiffed Betamax was that its advocates were reluctant to sell industrial-grade tape-replication farms to the adult industry. The VHS side had no qualms and would happily sell 1-to-100 duplication gear to anyone who waved a fistfull of Dollars/Zlotys/Roubles/Yen in their direction. Content is King. Even if it doesn't always render fleshtones perfectly. |
9th Jun 2017, 8:29 pm | #97 |
The Transputer. Sink of vast quantities of government money.
I had to evaluate it for BT in the 80s. My opionion was that it had an inadequate development environment for the complexity of its applications. A great idea to have a huge "meshed" set of processors, but it failed to get any real traction in the market against conventional processors. Made in Bristol, of course! Chris1900s (OP's) home town.
9th Jun 2017, 8:30 pm | #98 | |
For small-package Kilowatts-per-Kilogram power it's hard to beat a Wankel !! |
9th Jun 2017, 8:36 pm | #99 |
The Dolphin public access version of Tetra/Airwave. This was intended to replace/compete with NB3, the PAMR national trunked MPT1327 spec analogue radio system. I left the game just as one of our large customers was migrating over to it. I never found out what happened in the end but I suspect that someone was left with an awful lot of useless sets in various places. We trialled handportables and coverage seemed ok at the time. I wonder what went wrong?
Alan. |
9th Jun 2017, 8:41 pm | #100 | |
I spent time evaluating Transputers against the late- 1980s "mini-supercomputer" symmetrical-multiprocessor players like the i860, Alliant, Pyramid, Sequent, Convex - for various nuclear/geophysics/computational-fluid-dynamics stuff. Truth was, though when working on an optimal workload they could be blisteringly fast most of the time you had 63 processors sittimng idle and waiting for the 64th to complete its task. The Convex C-1 a client bought spent most of its time servicing Unix-shell command-line users. "Putting 64 wheels on a car doesn't automatically make it 16 times faster than a car with 4 wheels" as I was apt to tell people. |
