Old 17th Jan 2021, 7:42 pm   #41
beery
beery's Avatar
Default Re: My first telly TV22
Hi Travellingwave,
it looks like you have a TV22U or a TV22P, or simply a very late version of the TV22 (just before the TV22A was released) hence the 8K resistor. The set should also have a miniature PL81 for the line output instead of an octal PL38, can you confirm?
Trader sheet 1091 mentions this under 'Modifications'.
That resistor looks to be at least 10W, an 8K2 replacement would be fine.
Andy
beery is offline
Old 17th Jan 2021, 9:42 pm   #42
Travellingwave
Yes it has a PL81.
Travellingwave is offline
Old 17th Jan 2021, 9:46 pm   #43
Travellingwave
Yes I see the modification on the trader sheet makes sense now Thanks
Old 27th Jan 2021, 6:49 pm   #44
Travellingwave
Progress has been a bit slow due to work. Have done all waxies on main deck and moved my attention to main smoothing can. I had a go at reforming it , leakage seemed a bit high so have restuffed it. Opened it by filling away the lip holding the lid on.
Old 6th Feb 2021, 7:14 pm   #45
Travellingwave
Lopt back in after some fiddly soldering. Let’s hope it’s a good un
Bit cleaner than it was
ID:	226093   Click image for larger version
Old 18th Feb 2021, 11:19 am   #46
Travellingwave
I finally got all the recapping done
Applied power for first time - bit of smoke from some of the power resistors - heaters working, a bit of hum from the speaker.
I measured the HT at anode of V1 and only seeing about 50vdc
At this point I noticed that one of the rectifier valve anodes was starting to glow red hot so killed the power. I think it’s the boost diode side but need to double check , it’s the side indicated in the photo.
Old 18th Feb 2021, 11:54 am   #47
Travellingwave
After tracing the anode connections visually in the PZ30 Im pretty sure its the main rectifier that's glowing which ties in with the low HT , so somethings dragging it down. If Im right the schematic on the trader sheet is wrong as it has v10a as being the boost diode.
Old 18th Feb 2021, 2:44 pm   #48
Travellingwave
I guess most likely suspect is line output stage. I checked control grid voltage of the line output valve and have negative voltage here. I’m going to double check my work after replacing LOPt in case I made an error
Old 18th Feb 2021, 4:13 pm   #49
Travellingwave
Ive Isolated the HT rectifier and smoothing caps from the rest of the set - and I'm getting full HT now with a happy rectifier valve - so I will gradually reconnect stages to see where the fault lies. Before doing this I had disconnected the line output stage - I think by disconnected the HT feed to C32 - this did not cure the fault so it may not be the line output after all.
Old 18th Feb 2021, 7:20 pm   #50
Travellingwave
Found the fault
Old 18th Feb 2021, 7:23 pm   #51
Travellingwave
Made a schoolboy error restuffing the main smoothing bomb , surprised it didn’t go bang
Got line output and EHT judging by EHT rectifier valve lit and sound of corona from the tube anode. No raster yet will try with a signal tommorrow.
Old 18th Feb 2021, 7:52 pm   #52
Helder Crespo
Helder Crespo's Avatar
Looks promising! Could you hear the line whistle?
Helder
Helder Crespo is offline
Old 18th Feb 2021, 8:18 pm   #53
Travellingwave
Not really but my hearing might not be up to it. Def working getting EHT though sounds like an ioniser going.
Old 19th Feb 2021, 11:00 am   #54
Travellingwave
Got a raster - the black band is an artifact from camera
Grounded cathode of crt via a resistor , initially nothing but a quick tweak on ion trap got it going
Old 19th Feb 2021, 11:07 am   #55
Keith
Keith's Avatar
Well done - great feeling when you get that first light! Looks nice and bright too.
Keith Yates - G3XGW
VMARS & BVWS member http://www.tibblestone.com/oldradios/Old_Radios.htm
Keith is online now
Old 19th Feb 2021, 11:15 am   #56
beery
beery's Avatar
That's great!
Not far to go now
Andy
beery is offline
Old 19th Feb 2021, 2:02 pm   #57
Travellingwave
Hooked up the hedgehog - as far as I could see the tv was tuned to band 4 . Got a tone straight away and after a bit of fiddling I got a test card
Picture is a bit out of focus and adjusting the focus lever doesn’t seem to make much difference
Also I only get a picture with brightness turned right up to max , below that nothing , and contrast has to be fully clockwise too.
I haven’t changed any resistors yet and I know a few are out of whack so that may be the next thing
Any suggestions?
Old 19th Feb 2021, 2:02 pm   #58
Travellingwave
Banding is a camera artifact
Old 19th Feb 2021, 2:06 pm   #59
Travellingwave
I guess I ought to refit the LOPT shield
Old 19th Feb 2021, 2:08 pm   #60
beery
beery's Avatar
Check the CRT A1 (g2) voltage with a digital meter. It should be about 300Vdc. An AVO would load the supply too much to measure.
I also once had a TV22 with a broken wire wound track in the brightness control, which gave me nothing or an overloaded CRT depending on which half of the break the wiper was on.
Andy
beery is offline
