21st Nov 2022, 1:15 pm | #1 |
Pulse to Tone converter advice needed
Has anybody used this device shown below ?
It appears from the ratings that some people manage to get results and others fail. I would like to use the phone featured in the attachments, but I have a talktalk land line which I believe is incompatible with pulse dialling I want to use the land line not VoIP or ATA Any advice one how to go about this would be appreciated https://www.aliexpress.com/item/1005...d=IjG0SjVVGeJY |
21st Nov 2022, 4:37 pm | #2 |
Re: Pulse to Tone converter advice needed
In the 80's used to get by with a caller ID unit that stores incoming numbers which then allowed me to speed dial without using the telephone dial. Of course the downside is that you cannot enter add direct (they have to ring you first) to be added. The unit sits between the phone socket & the telephone instrument which would require your phone to have a UK Plug rather than direct wired - noting it seems to have an original line cord. Some people prefer using the dial for authenticity but nowadays most numbers are 11 digits which can be a bit of a faff compared to my memories when local numbers were only 4 x digits. Not sure if you still get them but internet search would confirm. It is likely the phone has a low impedance bell so you may also have issues with ringing if you add more instruments to the line thus exceeding the REN limit of [4] Good luck, Rog |
21st Nov 2022, 6:59 pm | #3 |
There are probably many devices out there, but I bought one of these:-
https://www.ebay.co.uk/itm/224769422...QAAOSwpZ5iTCFi It works very well, has proper UK BT connectors and doesn't need any PSU or battery.
Now where on earth did I remove that from? |
21st Nov 2022, 7:08 pm | #4 |
Hi there.
I've seen that converter advertised and wondered myself how well it works. (<edit> the one in post #1, not post #3, that's a new one on me.) Another unit called the "Dialgizmo" works in a similar fashion, and arguably has a proven track record with UK enthusiasts. There is also a little unit called the "Rotatone" which works slightly differently, and requires wiring directly to the dial contacts. A few of us on this forum have built units based on an ATTiny85 microcontroller that work similarly to the Rototone, I have a tele 232 using one and it works very well on my PABX system.
-- Graham. G3ZVT Last edited by Graham G3ZVT; 21st Nov 2022 at 7:18 pm. |
21st Nov 2022, 10:03 pm | #5 |
I can vouch for the Dialgizmo, being the owner of one. It is, however, more expensive at £39.95 and is sent from Australia.
22nd Nov 2022, 1:41 pm | #6 | |
22nd Nov 2022, 2:26 pm | #7 |
The chinese device I highlighted before has two connection points not three wires as mine has - green red and white.
Not sure where the white goes Here is a link about the wiring http://www.classicrotaryphones.com/f...p?topic=161.60 |
22nd Nov 2022, 7:27 pm | #8 | ||
Rog |
23rd Nov 2022, 3:24 pm | #9 | |||
23rd Nov 2022, 5:15 pm | #10 | |
The water only entered the PSTN O/P port which I unplugged straight away & has had many years to dry out. Rog |
23rd Nov 2022, 5:26 pm | #11 |
...and if it was only water (as opposed to something nasty like Coke), it will probably be fine.
