21st Nov 2022, 12:35 pm | #1 |
Microwave waveguide mica.
Hi Folks,
We've had our Schneider microwave for many years now - yesterday the bulb finally went kupat so i replaced it. When I was looking in, I saw thet the mice sheet by the waveguide had started to look a bit black so needed replacing. As the item was quite old now, the ones I saw on Amazon weren't the right size, so:
Mike. |
21st Nov 2022, 2:11 pm | #2 |
Re: Microwave waveguide mica.
Measure the time for a cup of water to get from ambient to the boil to assess power reaching the job in hand. Or run the thing for a short time while and check the temperature of the mica quickly afterwards. It has low thermal mass and 600W passing through it. If it's not hot, it must be OK.
Mica is usually punched to shape and to make holes. I assume drilling would work with support behind it for the drill to continue into. David
21st Nov 2022, 2:34 pm | #3 |
the biggest problem is going to be if it becomes conductive and starts sparking. I've ordered bigger ones and cut them down, using my hole punch to make a nice hole.
My panasonic here has a plastic waveguide cover as does this 1900W commercial microwave at work
Kevin |
21st Nov 2022, 2:54 pm | #4 |
Hi.
They get darker as they draw in grease etc, and eventually either fall apart or arc and burn. Often when they arc the arc will travel down the wave guide and damage the magnetron antenna so it's worth changing before this happens. You can buy a sheet of mica, or any larger wave guide cover and cut one out. I used to use a stanley knife and steel ruler, with the mica on a cutting board. Shape rounded corners with a sanding block. Holes are easy to make with a punch or drill bit.
BVWS member. |
21st Nov 2022, 3:35 pm | #5 | ||||
Thanks, folks, I'll have a look at all these replies.
I'll get a larger sheet from Amazon, drill on a wood block and cut with my ubiquitous Stanley Knife and round the edges with some glasspaper.
Mike. |
21st Nov 2022, 3:39 pm | #6 |
I vaguely remember reading something about cutting sheet-Mica with ordinary scissors, _underwater_ .
Mica being fragile, the scissors create their cut by micro-fracturing the mica; the underwater thing being to absorb the shock energy of the micro-fracturing and stop the mica delaminating in the area round the cut.
21st Nov 2022, 4:18 pm | #7 |
Hmmm ... interesting.
Mike. |
21st Nov 2022, 5:24 pm | #8 |
Location: Near Worcestershire/Gloucestershire border (in WR), UK.
May I ask if you find a suitable link(URL) to source sheet mica you share it, please?
Good luck! |
21st Nov 2022, 8:03 pm | #9 | |
Richard
BVWS member. |
21st Nov 2022, 8:26 pm | #10 |
21st Nov 2022, 9:13 pm | #11 |
Thank you muchly.
