9th Oct 2022, 4:26 pm | #1 |
Smiths No 1 movement in an unusual case
I have just finished restoring this rather attractive clock fitted with a Smith No 1 synchronous movement. The front pivot hole on the first (fibre gear) arbor was badly worn, causing noisy running. I rebushed the hole, a tricky procedure as the pivot is only 0.6mm in diameter, using a 0.6mm ID x 1.75mm OD tapered brass bush. The motor stator tested out perfectly on the Megger, and with a new flex fitted, the clock runs perfectly.
I am impressed with this movement, the first Smiths No 1 I have dealt with. It must have been very expensive to manufacture due to the precision nature of the movement, with no less than four stages of conventional reduction gearing, and the Bakelite case which houses the rear rotor bearing. The movement itself is aligned very accurately with the Bakelite housing, by three stepped-diameter brass inserts. This movement was introduced in 1931 and was superseded very soon afterwards, in 1933 by the “de-luxe” movement, which was of a different design using worm gearing. No doubt this was cheaper to manufacture. The only issue is, I can’t find anything like this clock in Barrie Smith’s book! Could it be a ‘marriage clock’? Phil
Phil Optimist [n]: One who is not in possession of the full facts Last edited by Phil G4SPZ; 9th Oct 2022 at 4:34 pm. Reason: Image attached |
9th Oct 2022, 7:52 pm | #2 |
Re: Smiths No 1 movement in an unusual case
Very nice! I’ve got several clocks with this movement, and whilst some are dead quiet, and be or two are rather noisy, presumably because of wear.
The worst thing about some of these is the bayonet-fitting bezel which can be a pain to fit, especially if someone has been heavy handed first. Great though Barrie’s book is, it’s far from a complete catalogue of all Smiths’ clocks, so I reckon your clock is original. |
9th Oct 2022, 8:52 pm | #3 |
Hi Nick, and thanks for your thoughts. The method of fixing the assembled movement and bezel into the case is a bit odd, because it’s clearly been ‘got-at’ before. There is a cast metal ring behind the chrome bezel; the movement slides into the ring from the front, backwards, and is held in place by three machine screws that pass through the ring and engage with three small curved metal retainers that hold the Bakelite case in the ring. Annoyingly, two of these screws are missing and they’re an odd thread, slightly smaller than 6BA and I can’t find anything to fit. The cast ring is then a friction fit inside the band behind the chrome bezel. The whole thing is, I think, held in place from inside the case by three screws and metal clips. All are missing.
If you could possibly let me see inside one of your original clocks with this movement, I can potentially fabricate something that will do the job, and I shall be forever grateful! On my example, the pivot hole had worn to the extent that the teeth of the fibre gear were rubbing on the adjacent arbor, causing the noise. You can actually see where the arbor has been polished by this rubbing action! As for Barrie’s book, it is remarkable that any manufacturer would have produced so many different models of clock, so it’s no surprise that a few are missing. I’m hoping that Smiths enthusiasts on this Forum and also at the NAWCC might be able to recognise it. Smiths certainly made some elegant models. I’m on the lookout for a chiming example or one of their pre-war long case clocks, if I can persuade SWMBO that is! Kind regards,
Phil Optimist [n]: One who is not in possession of the full facts Last edited by Phil G4SPZ; 9th Oct 2022 at 9:06 pm. Reason: Update |
9th Oct 2022, 9:32 pm | #4 | |
Phil, here are some notes that I jotted down for my own benefit when I last serviced one of these movements. I thought they might be worth sharing here, but please excuse any errors, misunderstanding and wrong terminology.
9th Oct 2022, 9:35 pm | #5 |
And this is what you normally find round the back:
9th Oct 2022, 9:38 pm | #6 |
Final thoughts for today: I know that Ferranti definitely marketed a synchronous, drum-type movement, with bezel, dial and hands, but without case. These often turn up in much older cases, presumably as a result of someone deciding to modernise a tired, old-fashioned clock in the 1930s.
But I'm not sure that Smiths did. |
9th Oct 2022, 11:44 pm | #7 |
Thanks for those notes, Nick. They pretty well reflect my own mental notes, apart from that when reassembling, I put the rotor into the back bearing first, then placed the movement into the case, guiding the rotor front pivot into its bearing, only applying oil and fitting the front end cap once the movement was fixed in the case, but I don’t think it’s critical in any way.
I was previously a Ferranti enthusiast, but I have got an equal number of Smiths and they all seem very well engineered. T R Robinson is also very complimentary about them in ‘Modern Clocks’ and gives full servicing details too. Thanks for the photo, by the way. My movement is fixed into its case in a different manner from yours.
10th Oct 2022, 2:23 pm | #8 |
I researched and wrote a history of Smiths. The pre-war clock business is a nightmare from vague entries in the 'HJ', to confusing model codes and stated dimensions, few of which agree! It didn't help that Smiths bought so many clock (and clock-case) companies... though none produced small electric clocks.
I can recommend 'Clockmaking in England and Wales in the 20th Century' (Glanville/Wilmuth) and 'Modern Electric clocks' (Philpott) as helpful guides. |
11th Oct 2022, 12:09 pm | #9 |
I have one of these ready to work on, different bakelite case though. I'll have to try and get some pictures up
The rotating disk that tells you the clock is running seems to have very fragile paint on it. A few pieces have simply fallen off with no help at all, so I'm trying to find a solution for that before proceeding. The push start knob had seized completely and needed lots of patience along with plus gas and heat to free it. The hands were as if they had been super glued on, I've never seen anything quite like it. I had to again use a heat gun, with some plumbers heat mat to protect the face. Despite all of this and being very patient, one hand did break in the process Adam |
11th Oct 2022, 2:00 pm | #10 | |
What's it called, please?
11th Oct 2022, 2:51 pm | #11 |
S Smith & Sons Ltd 'The Golden Years' - Brenelltape.co.uk. Part One: Timepieces, Part Two: Industrial, Motoring, Aviation, K&H....
12th Oct 2022, 12:19 am | #12 |
Why are clock books so expensive, I wonder? Philpott is anything from just under £30 to over £55. Glanville & Wolmuth is recently published and around £40. I suppose these books will never go out of date…
12th Oct 2022, 7:24 am | #13 |
I think £40 for G&W is well worth it. It's a big hardback, thick and full-colour throughout.
There's a limited marked for clock books, hence the higher per-unit price, I suspect. |
12th Oct 2022, 7:26 am | #14 |
Philpott is here as a PDF, free of charge: https://clockdoc.org/admin.aspx?moid=57422
12th Oct 2022, 9:05 am | #15 |
That is really helpful, Nick, thank you very much
12th Oct 2022, 9:52 am | #16 | |
17th Oct 2022, 6:20 pm | #17 |
17th Oct 2022, 10:28 pm | #18 |
I've skimmed through Philpott, and whilst it contains a vast amount of general information, together with some nice drawings, it has gone out of date. This, the second edition, was released in 1935, and consequently fails to cover a number of electric clock developments and movements that came along in later years. That said, it was an enjoyable read.
17th Oct 2022, 11:07 pm | #19 | |
18th Oct 2022, 7:40 am | #20 |
Wow! Excellent! Many thanks for that link.
