Old 4th Nov 2022, 10:32 pm   #1
Osvaldo LW1DSE
Osvaldo LW1DSE's Avatar
Location: Barrio Garay, Almirante G. Brown, Buenos Aires, Argentina
Default Restoration and modding a vintage Yaesu FT75B.
A friend gifted me this antique ham radio rig several years ago. It has been stored at home by those years, more. It is dated about the early 70's.
I restored it and modified it replacing several of the BJT's in the signal path and crystal oscillators enhancing the sine wave by them generated and reducing the noise and a slightly increase in its sensitivity. Note that this set ISN'T A HIFI DEVICE. It has been designed for ham radio use mainly, as a SSB (Single Side Band) or CW (Morse code) and the audio BW is severely reduced in order to limit the RF BW thus increase the number of channels in a ham band and concentrate the output power in only one of the dual AM sidebands. The unwanted sideband and the carrier is eliminated increasing the overall efficiency. Audio BW is restricted to spoken words and is from 300 to 3000Hz at best. A powerfull crystal filter is included at the IF stage to cancell out the unwanted SB and the carrier at TX and reducing the noise at RX. Unfortunatelly one of the front knobs was lost prior to own it.
Already I posted here the modification of the audio amplifier inside the rig and replace the original AN214 (burnt) with a pushpull of 2SK941 small power MOSFET's.
The tube final power amplifier is still inoperative. I need to build a multivoltage power supply including 250V for the 12BY7, about 500V for the 6DQ6's plates (paralleled), regulated 150V for 12BY7 & 6DQ6's screens and -100V for the biasing of the grids. The relay below depicted switchs the antenna to RX or TX stages and simultaneously maintain both grids bias well below the cutoff level in order to avoid interference in RX and tubes overheating. The front panel includes a switch that power up the heaters if it is wanted to transmit.
Originally the rig has 3 crystal channels per ham band although only one was provided by factory, installed. There is a switch that enables a rear input for an external VFO (Variable Frequency Oscillator), a means to cover the wide of each ham band.
The rear connectors are obsolete and difficult to find. So they were removed and replaced with commonly available ones. One of them has a free contact to ground in common to the band selector, on each band which enables an external power amplifier or VFO to act in synchronizity with the rig and a free changeover from the TX/RX relay. This has been replaced by a sub D 9 pin unit, and as I win some free pins, I hook a regulated 9V to it to power the VFO stage alone. The input of the external VFO now is carried by means of a DIN connector 5 pin where I added a 12V out for the VFO amplifier and adder. The jack for the CW key was removed as I hate Morse code, and in its place, a 100K pot is fitted to ajust externally the mic gain. Such a control was inside the mic amp and not available for the user. A 3.5mm mono jack was added too to use an external speaker, not included in the cabinet. A speaker terminal was included in one of the changed connectors but I prefer it separately.
I designed my own VFO using the 3 FM sections of it for each ones of the 3 Clapp oscillators made about 3SK40 dual gate MOSFET's. The rig is so designed that with 3 oscillators it can cover 5 bands, sharing part of the oscillators for two bands. A secondary winding in each oscillator coil (made inside of new TOKO 10mm cans) are serial wired and added to feed a 4th 3SK40 that decouples the oscillator from rig and the cable linking them. Each source is choosen by the connections in the 9 pin connector above mentioned. The 2nd gate of all MOSFET are all tied together to a voltage divider giving them about 4V stabilized, the point where usually those devices gives its best transconductance. There isn't risk of oscillator's mutual interference as only one of them is powered at a time.
The schematic of the entire apparatus, is of course, very large and available in the web in the scans of the original user manual. Those for the VFO, PSU and for the audio amp will be available soonly.
Enjoying high heel sandals, shoes or boots when I can.
Osvaldo LW1DSE is offline   Reply With Quote
Old 4th Nov 2022, 10:34 pm   #2
Osvaldo LW1DSE
Default Re: Restoration and modding a vintage Yaesu FT75B.
Some pics.
ID:	267416   Click image for larger version
ID:	267417   Click image for larger version
ID:	267418   Click image for larger version
ID:	267419   Click image for larger version
Old 4th Nov 2022, 10:36 pm   #3
Osvaldo LW1DSE
More pics.
ID:	267421   Click image for larger version
ID:	267422   Click image for larger version
ID:	267423   Click image for larger version
ID:	267424   Click image for larger version
Old 4th Nov 2022, 10:38 pm   #4
Osvaldo LW1DSE
Still more pics.
ID:	267426   Click image for larger version
ID:	267427   Click image for larger version
Old 4th Nov 2022, 11:43 pm   #5
Cruisin Marine
Looks like a smashing nice old rig, one which I didn't know of before seeing this post.
"Behind every crowd, there's a silver Moonshine"
Cruisin Marine is offline   Reply With Quote
Old 5th Nov 2022, 11:53 am   #6
Osvaldo LW1DSE
More info about this pet, here.
Old 6th Nov 2022, 1:18 pm   #7
Osvaldo LW1DSE
According to Argentine rules, we as ham radio operators have the following range in each band:
80mts: 3.5 to 4.0 MHz.
40mts: 7.0 to 7.3 MHz.
20mts: 14.0 to 14.35 MHz.
15mts: 21.0 to 21.5 MHz.
10mts: 28.0 to 28.7 MHz.
So, having the frequency chart of the FT75B extracted from the manual, I need the oscillator running at:
80mts: 8.627 to 9.127 MHz.
40mts: 12.127 to 12.427 MHz.
20mts: 8.87 to 9.22 MHz.
15mts: 15.87 to 16.22 MHz.
10mts: 11.43 to 12.22 MHz.
Thus taking round numbers, l have decided run them as:
80mts: 8.6 to 9.2 MHz.
40mts: 12.1 to 12.45 MHz.
20mts: 8.8 to 9.3 MHz.
15mts: 15.8 to 16.25 MHz.
10mts: 11.4 to 12.3 MHz.
It is then clear that 3 oscillators are needed:
For 80m and 20m from 8.6 to 9.3 MHz.
For 40m and 10m from 11.4 to 12.5 MHz.
For 15m alone, from 15.8 to 16.25 MHz.
The rounding is justified because no mechanical means home made can have high degree os stability and resolution for two or more decimal fraction values.
Name:	FT75B frquency.jpg
Old 9th Nov 2022, 6:03 pm   #8
Osvaldo LW1DSE
Now the VFO is +/- ok, then I shall make a box for it with a piece of thinker saved from the restoration of the roof many years ago. It has 12 x 12cm wide, and 5cm height. Sufficiently large to accomodate all parts, a PCB designed for it and in the front, some wheels saved from dismantled transistor radios. As I am old, l want my VFO looks as old as me.
ID:	267751   Click image for larger version
ID:	267752   Click image for larger version
ID:	267753   Click image for larger version
ID:	267754   Click image for larger version
Old 9th Nov 2022, 6:04 pm   #9
Osvaldo LW1DSE
One pic more.
Old 9th Nov 2022, 10:03 pm   #10
Bazz4CQJ
Bazz4CQJ's Avatar
That is not a rig I have ever seen before. In the UK the Trio (Kenwood) rigs TS520 and TS530 are popular old hybrid rigs, and there is the Yaesu FT101.
There are certainly threads on the forum about repair and restoration of those; just a guess, but there might be some read-across to your rig?
B
Bazz4CQJ is online now   Reply With Quote
Old 9th Nov 2022, 10:34 pm   #11
Cruisin Marine
Thank you Osvaldo, your posts and links are most interesting.
Old 9th Nov 2022, 10:56 pm   #12
dodgy-dxer
dodgy-dxer's Avatar
Bazz
You must have been snoozing!
The FT75 and FT75B were very popular in the mid-70s, particularly among the WAB crowd on 3760
They came with options of ac and dc power supplies, and a VFO. Crystal control with RIT was popular for mobile
They come up from time to time on eBay and I have one of each, and recently acquired a 2nd FT75B, almost by accident
A fun rig
73 Fred
G4BWP
B
dodgy-dxer is offline   Reply With Quote
Old 9th Nov 2022, 11:05 pm   #13
Bazz4CQJ
Bazz4CQJ's Avatar
By the mid-70's, my interest had moved to "other things".
B
Old 9th Nov 2022, 11:10 pm   #14
Jon_G4MDC
Jon_G4MDC's Avatar
I think I first saw one of those at a mobile rally at Grafham Water ( I think ) in 1975-ish.
Thanks to G8BI who drove me there when I was age 14 or so.
Jon_G4MDC is offline   Reply With Quote
Old 14th Nov 2022, 11:07 pm   #15
Osvaldo LW1DSE
Today l owned two new gangs for the future oscillator for the rig. They have a native reduction 3:1 in the shaft giving 1.5 turns in the main shaft to move 180deg the variable capacitor rotor plates. It surely will add resolution for tuning the thin width SSB signals. Both are equal, have 3 section for FM (now for the 3 VFO's) and two for AM that are useless in my project. They will remain unused.
ID:	268103   Click image for larger version
Old 14th Nov 2022, 11:13 pm   #16
Osvaldo LW1DSE
B
There is few info, but the most complete and interesant is the link I posted at #6. Includes set manual, pics of the time it appeared and data from the owner (seems to be a girl/woman).
Last edited by Osvaldo LW1DSE; 14th Nov 2022 at 11:15 pm. Reason: Typos and more typos :-(
Old 16th Nov 2022, 2:15 pm   #17
Osvaldo LW1DSE
The new gang with reduction was instaled on the protoboard of the prototype VFO. Some capacitor need to be changed as it appear that the gang has different parameters respect the previous used.
Name:	New Gang 01.jpg
ID:	268197   Click image for larger version
Name:	New Gang 02.jpg
Old 16th Nov 2022, 5:03 pm   #18
Cruisin Marine
Nice work Osvaldo
Old 16th Nov 2022, 11:05 pm   #19
Osvaldo LW1DSE
Thank you !!!
Old 18th Nov 2022, 8:08 pm   #20
Osvaldo LW1DSE
The small chassis for the VFO has been tin soldered at the corners using a tiny quantity of HCl acid. Now it is ready for make the PCB.
ID:	268297   Click image for larger version
