3rd Dec 2012, 8:27 am | #1 |
860 Teasmade noises.
Hi all,
I have just bought an 860 model Teasmade and it works OK but the clock is making a clicking noise, sounds a bit like something needs lubricating or is perhaps slipping. I have read answers from my previous post and lubrication was mentioned as a common fault (and removal of old lube). Anybody have any ideas? I think it is the clock because there is not much else working when no water is being boiled. |
3rd Dec 2012, 10:13 am | #2 |
Re: 860 Teasmade noises.
It will be noise from the clock motor, and either lack of lubrication or wear, especially on the plastic worm.
Very unlikely to be anything slipping, but that would make it lose time.
Mike. |
3rd Dec 2012, 10:54 am | #3 |
What would you recommend to lubricate the plastic worm, Mike?
3rd Dec 2012, 5:59 pm | #4 |
I tend to use turret clock oil, Nick, but I think any car engine oil should be fine. It needs to be a bit thicker than clock oil.
Mike. |
3rd Dec 2012, 8:00 pm | #5 |
Thank you Mike and Nick, I am about to operate on my first teasmade. Any guidance re clock motors really appreciated, especially how to remove clock for repair.
Also the 860 came with full user instructions, if these are rare I will post them for all to download. I am not sure what is hard to get and what is not. Anyhow great site and helpful people, glad I found you all. |
5th Dec 2012, 4:37 am | #6 |
I'm still struggling regarding the right way to remove the clock from my 860 Teasmade. It has stopped working altogether and I do not want to break anything doing it. For instance, does the hand adjusting knob just pull off? I thought I could prise it back out with a screwdriver. I have taken a photo of the wiring so I can get all that back ok. I am being really careful here because of the no spare parts situation. Any help appreciated. |
19th Dec 2012, 6:24 am | #7 |
Hi all,
My clock is not working so I have taken the motor out and removed the rotor and drive shaft. I can see two wheels inside the clock, one is red and it is in mesh and seems to be ok, the other is yellow and it is not in mesh as it just turns when I move it with a screwdriver. I think this could be the problem although I am not sure as it could be just a support for the motor shaft, the motor shaft has thread down to about halfway and does not appear to be stripped. Is there anybody who has some experience with these clocks? The clock looks like a sealed unit and I am not sure I can go any further. If this is the case I suppose I could just use the "Tea now" button and not use the clock, any suggestions? |
20th Dec 2012, 10:06 am | #8 |
At this point, I think we really need pictures to see what's actually happening to the motor.
Mike. |
23rd Dec 2012, 9:14 pm | #9 |
I have the motor out and shaft looks ok, what I really need to know is how to test he motor for correct function. It has two grey wires attached, how do I tell which is the active one and then how to test it? A photo would not show much as all I have is the motor as described and a hole in the clockworks where it came from. Trying to decide if the motor or clock itself is faulty. I have a couple of spare motors on the way from the UK at the moment, so I am hoping it is the motor. Cheers! |
24th Dec 2012, 12:30 am | #10 |
As a first test, measure the resistance between the two grey wires on the disconnected clock motor using a multimeter on a resistance range. Start on the 2kΩ range and work up through the ranges until you get a sensible reading (i.e. not "overload", usually indicated by just a 1 in the leftmost position of the display, but in any case whatever is seen with the meter on a resistance range and the probes not connected to anything). If you get "overload" on all resistance ranges, it means the motor winding has failed open-circuit. This is the worst that can happen, but is still recoverable.
The Teasmade I have (not sure of model no., but it is a 1970s-style one with rotary mode switch) used a hefty wirewound resistor in series with the motor. If yours has such a resistor, measure its resistance with a multimeter. Post the results of your initial tests and someone will get back to you .....
24th Dec 2012, 1:05 am | #11 |
From message #1 I got the impression that the start direction device was rattling or clicking.
I think it is supposed to move clear once it has done its job. I guess it has got a dab of grease on it that has dried out. It will be on the first gear the motor drives in the movement. My father cut a piece off one on an alarm clock to stop it "ticking" thinking it was there to reassure the owner it was working and that it did not serve any other purpose. The clock went backwards. |
24th Dec 2012, 3:21 am | #12 |
Thank you AJS and Refugee I will check and measure as suggested, and get back soon as possible.
Cheers |
24th Dec 2012, 10:27 am | #13 | ||||
You should be able to run the motor without the rest of the clock movement. Quote:
Don't think Entellus' 860 has one.
Mike. |
26th Dec 2012, 4:47 am | #14 |
Thank you all, could somebody tell me how to test the motor while out of the clock?
Thanks. |
26th Dec 2012, 4:50 am | #15 |
Forgot to mention that I do not know how to insert a photo!, will post one of motor as requested when I know.
26th Dec 2012, 10:00 pm | #17 |
Thanks Mike!
26th Dec 2012, 10:23 pm | #18 |
Have uploaded photo, hope this is right!
26th Dec 2012, 10:41 pm | #19 |
Yes, there's a series resistor. Looks like brown, red, orange = 1 2 000 = 12K, a couple of watts.
First do cold tests: with the unit unpowered, measure the resistance between the two ends of the resistor, and the two grey wires on the motor. See earlier posting by me. If both are OK (post readings here if in doubt), and you feel comfortable doing live tests, then proceed as follows: Connect either the resistor in the Teasmade, or (if that turned out to be open-circuit) another resistor of the same value and wattage, in series with the motor; fix a bit of tape to the pinion gear, to see if it moves; then power it up and see what, if anything, happens.
27th Dec 2012, 3:55 am | #20 |
Hi AJS, I have an autoranging multimeter, I put it on resistance and got the reading 5.57 when I put the probes on each of the grey wires coming from the motor. Did I do this OK? Not very experienced with the meter. I guess this means the motor is ok? Not sure. Await your wisdom on this one.
Regards |
