Old 17th Sep 2021, 12:08 pm   #1
ghargrave
Default Getting a Pye TV to pick up signals - would LOVE some help.
Hi everyone!
Total noob here so please be gentle, haha.
For reasons I am not entirely sure of, I have become determined to turn an old, portable Pye TV into a working set. What possessed a woman with no pre-existing knowledge or experience to take on such a project? Who's to say? Must be lockdown-fuelled insanity.
Anyway, I digress.
Here's the television. She picks up black and white static and I can even hear some radio stations come through on certain channels.
I have plugged HDMI input into this converter, so the HDMI is now analogue. So far so good.
Now, I want to take that analogue output and turn it into an RF signal for the TV to pick up.
I have this RF modulator:
And this antenna and amplifier:
Anyway, dear reader, I have tried multiple set ups and gone through all the channels and tuning and everything I could think of, but I am not having any luck at all.
Am I missing something obvious (likely)? Doing something dumb (even more likely)? Is what I am trying to achieve even possible?
Thank you for any kind and patient help you can give me. If you can explain to me like I'm 5 years old that would be very helpful.
I am in Australia if that makes a difference.
ID:	241503   Click image for larger version
ID:	241504   Click image for larger version
ghargrave is offline
Old 17th Sep 2021, 12:34 pm   #2
Station X
Station X's Avatar
Default Re: Getting a Pye TV to pick up signals - would LOVE some help.
Hello and welcome to the forums.
A bit of searching sugests that the Pye Twelve was made in VHF and UHF versions.
Is yours a UHF version?
Does the tuning knob rotate freely or does it click into distinct positions?
Any chance of a full model number?
Graham. Forum Moderator
Station X is offline
Old 17th Sep 2021, 12:44 pm   #3
Station X
Station X's Avatar
A similar model with rotary volume and brightness controls.
https://www.radiomuseum.org/r/pye_au...25_series.html
This is a VHF only model. 13 dots around the tuning knob suggests that yours is also VHF.
If yours is a VHF model you'll need a VHF modulator rather than a UHF one. Also I'm not sure whether Australia used 405 lines or 625 lines on VHF. If 405 lines you'll have some difficulty generating a signal.
Old 17th Sep 2021, 12:50 pm   #4
AdrianH
AdrianH's Avatar
Can I ask what model TV it is, so that one can check if it is VHF or UHF receive and what system. The dials may be very different between Australia and the UK but old VHF dials here started with 1 and went to 13 , UHF typically started around 23. If you are hearing some music on some channels I would assume a VHF TV receiver a bit like our old 405 line system.
May be able to suggest what channels on the TV match a channel on the modulator If I can find the manuals on line. Do you have any combinations where the screen goes black or give any vertical bars etc?
Adrian
Slow typing and searching at this end
Asking questions and learning, or trying to!
Youtube EF91Valve
AdrianH is online now
Old 17th Sep 2021, 1:15 pm   #5
paulsherwin
paulsherwin's Avatar
Australia never used 405 lines. TV launched with 625 lines on VHF.
paulsherwin is offline
Old 17th Sep 2021, 2:39 pm   #6
Lloyd 1985
Lloyd 1985's Avatar
It sounds like you are going about it the right way, one thing I’d say is you don’t need the antenna and amplifier, I’d connect the RF output of the modulator directly to the antenna terminals on the back of the TV. It does say it’s a universal modulator, channels 0-75, so if it’s anything like the one I’ve got here then you can use it for both VHF and UHF, just by selecting it on the modulator. Hopefully it has some instructions on how to select the VHF channels, mine has some awful menu that requires certain buttons pressing, which puts it into the menu which is navigated by 2 digit codes... not the most intuitive thing in the world!
Regards
Lloyd
Lloyd 1985 is online now
Old 17th Sep 2021, 2:51 pm   #7
Station X
Station X's Avatar
I found a spec for that modulator and it does both VHF and UHF.
Old 17th Sep 2021, 3:22 pm   #8
staticmind
As Lloyd also said, you don't need the antenna and amplifier.
You need a coaxial cable (antenna cable) with F connectors. One of the ends you connect to the TV/VCR F-connector on the modulator. The other end should be connected to the TV. As antenna cables back then were twin leads, you'll need to wire it up to the TV using an adaptor.
My suggestion would be to buy an F-connector to BNC adaptor like this: https://www.bhphotovideo.com/c/produ...le_to_bnc.html
and then a BNC to terminal block like this: https://www.gmelectronic.com/connector-tp-006, and then connect two wires from the terminal block to the TV aerial.
What is the stated RF output level on the modulator? You might need an attenuator in order not to overload the input. Level below 80 dBµV should be good.
staticmind is offline
Old 17th Sep 2021, 3:47 pm   #9
Lloyd 1985
Lloyd 1985's Avatar
One of these would connect the F connector to the TV's twin lead input, hopefully available in Australia, as the shipping from the US is expensive!
Regards,
Lloyd
Old 17th Sep 2021, 4:36 pm   #10
kan_turk
kan_turk's Avatar
Hi
TV is almost certainly VHF only as a UHF only set would have been useless in Australia, or anywhere else for that matter with the single exception of GB who travelled a different path from the rest of the world.
Proceeding with this assumption you will need the converter and the modulator
only.
Connect modulator output (marked TV) to TV antenna input - switch TV to ext ant (switch on rear of TV) -ideally you should have a balun here to go between the coax output of the modulator and the screw terminals of the TV antenna input but it should work without this - set modulator to a low VHF channel - say ch 2.
Set TV tuner to ch. 2 - you may have to experiment with this as channel numbErs appear to have worn off
Connect converter AV out to modulator AV in (RCA plugs)
Connect source device (DVD player or whatever
You may have to fine tune TV for best picture/sound
Also it is no harm to be aware that some material is copy protected and may not display correctly
Hope this helps - it takes longer to describe than to do - honestly
Best of luck and please don’t hesitate to ask on here if you run into difficulties
Rgds
John
kan_turk is offline
Old 17th Sep 2021, 9:02 pm   #11
patrickgnl
In addition to all of the above I would add that its a good idea to set the original signal HDMI device (DVB-T tuner, blu-ray or DvD player) to output in 576i, as the converter may not do this automatically. It should as it has composite out, but just in case…
patrickgnl is offline
Old 17th Sep 2021, 9:07 pm   #12
agardiner
agardiner's Avatar
Also, please let us know how you get on. It is always nice to know when there is a successful outcome.
agardiner is offline
Old 18th Sep 2021, 2:53 am   #13
Clydeuk
In the third picture it shows a switch for internal and external antenna which is set to internal. Not sure this would completely block a signal applied to the antenna terminals but worth setting it in the external position before connecting the modulator.
It might also be worth trying your setup on another set just to confirm it's working. A modern set will be ok to try providing it still has the option to receive analogue signals via the aerial (more recent equipment may not have this option)
Clydeuk is offline
Old 18th Sep 2021, 4:20 am   #14
red-duck
red-duck's Avatar
Hi Mrs Noob.
This should be easy.
You don't need the antenna/amplifier just the modulator.
You have an Australian set that would pick up the old VHF channels (0-11 including 5A). You will hear FM station on channels 3,4 & 5 as they were within what is now the FM band.
Turn on your modulator - select channel 01 0r 02 using the CH+ - buttons on top of the modulator. Avoid using channels 6,7,8, 11 as they are used for your local digital TV stations
Get an antenna cord with F connectors on each end (from Bunnings or other hardware store). Cut off the plug on one end, with a sharp knife cut off a couple of cms of insulation and the underlying metal foil and connect the inner conductor to one of the screw terminals on the back of the TV (select external).
Connect up the cord, turn on you video source and turn the channel selector on your TV to Channel 1 or 2 depending on what you have set up. If there is no numbers ... turn the selector until you see a picture. Then fine tune with the larger knurled part of the knob on the outside of the channel selector.
Best Regards
Nigel
VK6CPU
Perth, Western Australia
red-duck is offline
Old 18th Sep 2021, 8:28 am   #15
ghargrave
Just a quick reply to say THANK YOU SO MUCH to everyone! I am really grateful for your expertise, or more importantly, your kindness in taking the time to type it all out.
I have loads of leads to try now so hopefully I can get back to you all very soon with a success story.
Lots of love! Thank you! xx
Old 18th Sep 2021, 1:59 pm   #16
ghargrave
Regards,
Lloyd
Hi Lloyd great, so I could just use that to connect the modulator directly to the TV? Forgive me but how would the 'pincers' (for lack of better phrasing) physically connect to the TV? Do I just wrap them around the screws at the back?
Hi John, you're a champion, could you please show me an example of a balun, that's a new word for me Is it like what Lloyd has linked above?
Hi Nigel, thanks for the runthrough! Is doing what you've described here an alternative method for what Lloyd and John (kan_turk) have spoken about, or is there some sort of magic I'm not aware of when you cut up a coax cable?
Old 18th Sep 2021, 3:33 pm   #17
kan_turk
kan_turk's Avatar
Hi
1. Device linked by Lloyd is a balun
2. If you loosen screws on back of set it should be possible to insert the ‘spade’ connections on the balun under the washers/screws & then tighten the screws
3. Method suggested by Nigel applies if you are not using balun and should work fine
Either way be sure to move switch to ‘EXT’
Hope this clarifies
Rgds
John
kan_turk is offline
Old 19th Sep 2021, 8:38 am   #18
ghargrave
GUYS GUYS GUYS.
IT WORKED. I'M SO EXCITED.
Thank you all SO MUCH for your help!
Here's a video of it in action. I am streaming the clip from YouTube. https://vimeo.com/608810670/998f20aa02
Old 19th Sep 2021, 11:21 am   #19
Lloyd 1985
Lloyd 1985's Avatar
Congratulations! Pleased it worked
Regards,
Lloyd
Old 19th Sep 2021, 2:37 pm   #20
kan_turk
kan_turk's Avatar
Brilliant - great work - it’s very satisfying when a plan comes together - well done
kan_turk is offline
