Old 16th Sep 2021, 3:46 pm   #1
Skywave
Question Panasonic LCD TV: strange display fault.
Model is TX-32AS600B. On the lower half of the screen there is a horizontal line of rings, equally spaced, polo mint shaped but larger and although quite faint, this is clearly indicative of a fault condition.
Any suggestions to the cause and fix, please?
Thanks.
Al. / Sept. 16th.
Skywave is offline
Old 16th Sep 2021, 4:48 pm   #2
Andrew2
Andrew2's Avatar
Default Re: Panasonic LCD TV: strange display fault.
I don't suppose this could be image retention from some previous application? I know LCD's are not supposed to suffer IR, but I'm sure if someone tried hard enough it could happen!
Andy G1HBE.
Andrew2 is offline
Old 16th Sep 2021, 5:51 pm   #3
greg_simons
greg_simons's Avatar
This sounds like a common problem on these models, caused by the ingress of dust into the diffusion filters of the lcd panel, we did used to clean them at the time, it's a two man job lifting the various parts evenly without breaking anything, also clean the back light led strips, although i would stress it's not the easiest of jobs and not to be undertaken unless you think you can manage it?
Greg.
Picture, sound?, DOOR.
greg_simons is online now
Old 16th Sep 2021, 6:07 pm   #4
Lloyd 1985
Lloyd 1985's Avatar
Could it also be the lenses dropping off the LED’s? I’m sure someone else had that happen on here not long ago with a Toshiba.
They could really do with making the back lights accessible from the back, so you don’t have to pull the whole screen apart!
Regards
Lloyd
Lloyd 1985 is offline
Old 25th Sep 2021, 10:52 pm   #5
lightning
lt's easy to tell if it's the lenses that have fallen off, turn the set upside down and you'll hear them fall from the top to the bottom inside.
As already stated, it's a common fault with some types of LED backlight.
lightning is offline
