3rd Aug 2021, 11:01 am | #1 |
Replacement Relay needed Diamond H Controls
Hi, I have a kiln that is buzzing and I have narrowed it down to the relay, its a Diamond M controls number BW240A02 147, does anyone know a supplier that still stocks these or know of a direct replacement? thank you for any help received.
Last edited by Radio Wrangler; 8th Aug 2021 at 10:53 pm. Reason: Diamond H, not M |
3rd Aug 2021, 11:05 am | #2 |
Re: Replacement Relay needed Diamond M Controls
Hi Paul
Welcome to the forum. Any chance of a picture of the relay? Cheers Mike T
3rd Aug 2021, 12:13 pm | #3 |
Is it possible that it is Diamond H and not M?
If so, Heatrod in Bolton own the brand and do a range of process control relays and contactors. Otherwise show us a picture, relays are often generic. https://www.heatrod.com/industrial/i...rs-and-sensors
-- Graham. G3ZVT |
8th Aug 2021, 7:14 am | #4 |
Hi, here are a couple of photos of the labels, cheers
8th Aug 2021, 3:35 pm | #5 |
That's more like a Contactor
Might pay you to rewire if for something current. Cheers Mike T
8th Aug 2021, 8:46 pm | #6 |
That confirms it's Diamond H, have you contacted Heatrod?
You don't say what part of the kiln is buzzing and if the kiln works or not.
-- Graham. G3ZVT |
8th Aug 2021, 10:54 pm | #7 |
Re: Replacement Relay needed Diamond H Controls
Title edited to Diamond H
22nd Aug 2021, 3:49 pm | #8 |
I work in the Switchboard (Industrial Motor Control) sphere, so may be able to help.
What sort of connections are on the relay? - Are they 1/4" tabs (faston) or does it have a plug-in base? or is it soldered in? Looking at the ratings on the can, there are a number of modern relay you could replace it with - Finder, ABB, Schneider to name a few. If you can give details of connection and mounting I can suggest a replacement for you. If you don't have access to a wholesaler, I could get one for you also. Regards. |
