16th Jul 2021, 7:47 pm | #21 |
Re: How rare are these plugs?
Hi.
I've around half a dozen of them and they are used every day. I have a 12v solar system in my shed and they are ideal. I have my amateur 2 meter transceiver, 12v soldering iron, standards converters, freeview boxes and other items that use the 12v with these 5 amp fused plugs.
17th Jul 2021, 12:50 am | #22 |
When I built my darkroom in my teens, I made a mains distribution board using Bulgin plugs and sockets, item 10 here: I'm not sure why I chose those, but in 1969 the ubiquitous 13A power strip was yet to become a thing.
Yikes, it says on that site that the original ones were only rated for 50V!
-- Graham. G3ZVT |
17th Jul 2021, 7:49 am | #23 |
I think the 50V rating is about accessibility of live conductors rather than what the connector can handle. See also legend in image 12.
17th Jul 2021, 9:40 am | #24 |
The 50 volt rating was because they could be opened without tools, just unscrew the cap. I remember seeing BC lamp holder adaptors fitted with a locking screw to comply with the new ruling. If those Bulgin connectors were used inside an equipment cubicle or case, then they were OK as they were. Cheers, Pete.
18th Jul 2021, 5:12 pm | #25 |
Hi ,
When I worked for the DECCA Empire back in the 70s and 80s 98% of the test equipment had the 2A version fitted , Some even had 10A fuses fitted. All the testing stations / benches were plugged into 13A sockets with red pigmy lamps half way up the supply conduit , so at night they knew all the benches were turned off. |
19th Jul 2021, 9:47 am | #26 |
I remember repairing a Clarke & Smith 8812 schools tuner/amp that had a chassis 2A
socket. As it was unshuttered I supplied a new unattached plug to prevent contact. |
19th Jul 2021, 3:28 pm | #27 |
Administrator
If you are on Facebook you may like this "Vintage mains plugs and electrical curiosities" group: https://www.facebook.com/groups/716156685782212
19th Jul 2021, 11:52 pm | #28 |
I've gad a good look at that site it's really good I would recomend it
25th Aug 2021, 9:29 pm | #29 | ||
