Old 8th Apr 2017, 5:05 pm   #1
60 oldjohn
Default Even more items to date.
Anyone know when these items first went on sale?
1 Belling Bed Warmer.
2 A Bakelite bed warmer.
3 Another "Magnet" I presume GEC saucepan with an element.
TFL, John.
ID:	140652   Click image for larger version
ID:	140653   Click image for larger version
ID:	140654   Click image for larger version
ID:	140655   Click image for larger version
60 oldjohn is offline
Old 8th Apr 2017, 5:15 pm   #2
60 oldjohn
Default Re: Even more items to date.
4 A Black & Decker model B Drill, 30v-50v ? AC/DC. Made in England. Voltage ? it has a 13amp plug fitted!
TFL John.
ID:	140657   Click image for larger version
Old 8th Apr 2017, 7:38 pm   #3
robin coleman
The Bakelite bed warmer is probably from the 1940s. My late grandmother used to put one in my bed in the 1970s as a child. We also had a brown bottle shaped one. The kettle is probably about the same age. We used to get a few of these at my grandfathers scrap yard.
Regards
Robin
robin coleman is offline
Old 8th Apr 2017, 7:47 pm   #4
dseymo1
The drill wll be 230 - 250V mains operated - the '2' just hasn't been very well stamped on the rating plate.
dseymo1 is offline
Old 8th Apr 2017, 10:21 pm   #5
Paul_RK
Paul_RK's Avatar
I can't think where my 1927 Sunco catalogue is currently hiding, but the saucepan looks at least old enough to be in it.
Paul_RK is offline
Old 9th Apr 2017, 7:52 am   #6
dseymo1
Checking online images, the 1944 B&D of this style seems to have had an embossed brass plate, rather than a printed aluminium version, so I guess yours is a little later than that.
dseymo1 is offline
Old 9th Apr 2017, 8:35 am   #7
David G4EBT
David G4EBT's Avatar
There are lots of identical Bakelite bed-warmers on ebay, invariably described as '1940s' mostly made by 'Veret', some with their original box and instructions.
Typical information from the 6-page fold out instruction leaflet states:
The VERET Electric BED WARMER.
Made by Veret Ltd. 136 Woolwich Road, Abbey Road, London SE2.
No more cold beds for my Guests - 150 Hours warmth for ONE PENNY
Instructions:
Special Reinforced Bakelite is Heat-Proof and Heat-Absorbing Container
Should be used in Beds or AIRER Linen in cupboard.
200V - 250V Electric Thermostatically Controlled.
Just plug into the Lamp (Light Bulb Fitting)
SIZE: 235mm Tall & 90mm Wide
+ 3m (3000mm) Electric Cable.
They came with a velour case, but whether or not that was an optional extra, I've no idea. Either way, with the passage of time, it's easy to see how the velour cover would become worn, lost or discarded.
Original price 16/6d.
Assuming that was in 1945, it equates to about £30.00 now when adjusted for inflation.
I'd have thought that the copper electric saucepan was more late 1930s, and the B&D drill 1950 - 55.
Hope that helps a bit John.
David.
BVWS Member.
G-QRP Club member 1339.
David G4EBT is offline
Old 10th Apr 2017, 5:43 pm   #8
Brigham
The Belling Bed Warmer (No.90) is listed in the 1953/4 catalogue, and still appears in 1961/2.
Colours are initially 'pastel shades of blue, pink or yellow', but by 1955/6, only blue is mentioned. By 1957/8, the three colours are back, but by this time 'yellow' has become 'primrose'.
Power is a frugal 40 Watts, chiefly because the heating element is a 40w bulb.
List price in '53/4 is £2/2/9 inc. p.t.. rising to £2/5/1 (inc.p.t.) in '61/2.
Brigham is offline
Old 10th Apr 2017, 7:48 pm   #9
60 oldjohn
Thank you every one for your help. It is nice when there are catalogues with the items in.
John.
Old 10th Apr 2017, 11:00 pm   #10
emeritus
The "Magnet" saucepan probably dates from the inter-war period. The cooking utensils in the 1911 GEC catalogue are referred to as "Archer System", and as far as I can make out, the connector pins were proud, not recessed, mating with a free 2-pin socket.
The initial letter of the "Catalogue No" probably refers to the section of the then-current GEC catalogue in which it was listed. In the 1911 catalogue, cooking apparatus are in Section H, and the product codes are all prefixed with "H". Similar saucepans are shown, but they stand on three legs, and the knobs on the lids are completely different. The archive of GEC catalogues that used to be kept in the Marconi Museum are now in the Bodliean Library, Oxford. Yours would be in a GEC catalogue in which cooking utensils were in part D.
emeritus is offline
