1st May 2014, 12:19 pm | #21 |
Re: 1 Amp mains Cable
It depends on whether equipment or personal safety is involved. And on the equipment and whether you are working live etc etc.
I would say that any unearthed soldering iron should be fed from an isolation transformer.
1st May 2014, 4:55 pm | #22 |
Product liability is what has changed. A fault that shorts the element core to the shaft could be fatal. I had an immersion heater element do that a few years back, the RCD tripped along with the circuit MCB.
BVWS member |
1st May 2014, 8:13 pm | #23 |
Its not only about safety. We had a major issue at work some years ago where the leakage current through an unearthed tip was destroying static-sensitive components.
Regards, Richard, BVWS member |
2nd May 2014, 6:47 pm | #24 |
Earth it if you value your life
Kevin |
11th May 2014, 10:30 pm | #25 |
My old bench tester used to have 0.25mm flex on it! I changed it as it was quite tatty and really, 0.25mm feels far too fragile for use, especially on An iron! I used 0.5mm when rewiring my antex. It's readily available so would probably be the best option!
12th May 2014, 8:44 am | #26 |
Earthing
I never work on live circuitry I haven't got that doddery to forget yet. and as I only ever work on analogue circuitry it should be ok non earthed, I think two core is the route to go, the silicon cable seems a better compromise rather than standard 3 core cable but so far for what I want it is too expensive. days gone by you could use a bit of wet string and connect it to the ceiling light with no complaints from health and safety Thanks lads for all your input on this subject Gary |
12th May 2014, 1:45 pm | #27 |
Farnell Instruments used it on much of their low power equipment. I have the end of an
RS reel of what was sold then, pvc 3-core "New" colours, grey sheath diameter about 4mm. So there must be some out there. |
13th May 2014, 12:04 am | #28 | ||
I've only ever seen it new colours, I assume it was made early to late 70's and probably phased out near the 80's (going by the type and age of various pieces of kit I have seen it on) Quote:
Granted not common nowadays and I definitely wouldn't use flex that thin, but the theory is the same as using a 3a fuse to protect 3a rated 0.5mm flex. |
17th May 2014, 7:41 pm | #29 |
I have about 6ft left of 3 core 0.25 if you want if for free? P.M to follow .
18th May 2014, 10:46 pm | #30 |
If this cable is not taken I would love to have it for the restoration of My Marconi TF1041C
Al
I won't tell you how I discovered that. |
23rd May 2014, 10:12 pm | #31 |
Sorry , It has gone now Thanks
