Old 14th Sep 2011, 10:23 pm   #21
grundigsatelite
Default Re: Bush wall clock Radio
very good john also your clock radio will work on a 9v mains adaptor but the only pitfall is you end up with a unsightly trailing wire on the wall . but does it it also work the clock ?? or just the radio >
Very good, John. Also your clock radio will work on a 9V mains adaptor. The only pitfall is you end up with a unsightly trailing wire on the wall, but does it also work the clock? or just the radio?
grundigsatelite is offline
Old 15th Sep 2011, 8:59 pm   #22
60 oldjohn
The 9v conector is for radio only. I have checked clock power consumption, seems ok between 0.3ma and 0.03ma. The clock is loosing a few seconds a day, I hope the adjustment will correct this. John.
60 oldjohn is offline
Old 24th Jun 2015, 12:00 pm   #23
crablogger
crablogger's Avatar
Hello
Realise this is a pretty old post... have just bought one of these in a dreadful state and some tinkerer has been at it, a number of components are missing and as I've had no joy tracing a diagram, wondered if anybody has some really clear pictures of the component board to save me a lot of time. Cheers.
crablogger is offline
Old 25th Jun 2015, 7:53 am   #24
trsomian
The earlier reference to cogs and gears is not quite correct. Cogs are the teeth of a gear. Cogs fit in a cog wheel to make a gear. Thus clocks do indeed contain gears
trsomian is offline
Old 25th Jun 2015, 8:56 am   #25
Mike Phelan
Mike Phelan's Avatar
To be a bit pedantic and despite the fact that the post referred to is now ancient, clocks don't have gears or cogs!
They have wheels which have teeth; pinions have leaves.
Crablogger, hope you have some luck; is it the radio or the clock parts or both that you need to sort out?
Mike.
Mike Phelan is offline
