Old 13th Apr 2015, 5:52 pm   #1
Aaamusements
Default 1980s? Sharp R8000E microwave and convection oven
This was chucked out as scrap but I thought it might have salvageable components inside, considering the age it's probably a lot better made than he modern stuff?
Aaamusements is offline
Old 13th Apr 2015, 7:58 pm   #2
Default Re: 1980s? Sharp R8000E microwave and convection oven
It probably does. A friend still has one and she prefers it to the modern fitted oven in her kitchen. The turn-on button takes a bit of a knack to get it to hold in, though.
I've tried looking for something new with the same capacity and capabilities... nope.
The ergonomics are good too.
I suggest you clean, fix and use!
Radio Wrangler is online now
Old 13th Apr 2015, 8:42 pm   #3
Aaamusements
I'd be keener to keep it if it didn't have quite so much German Shepherd upholstery!
Old 13th Apr 2015, 9:18 pm   #4
keithinuk
My one came from BeJam's, still doing its job and a lot bigger then the new one's you can get.
keithinuk is offline
Old 13th Apr 2015, 9:56 pm   #5
Richard
Richard's Avatar
Hi
Several makes of combi ovens of this era were prone to the perforated vents at the back of the cavity rusting away, then they leak microwave energy, worth checking.
Richard
BVWS member.
Richard is offline
Old 13th Apr 2015, 10:49 pm   #6
mark pirate
mark pirate's Avatar
Take it outside and give it a good scrub, I am sure it will clean up nicely and have many years left in it
These were certainly better quality than anything you can buy now.
Just a note of caution. If you do open it up, make sure that you ground the big capacitor, just in case the bleed resistors are O/C!
Mark
mark pirate is offline
