Old 16th Aug 2020, 4:38 pm   #1
novicerepairer
Default No’s worn off Trio Amp Facia
Hi, this is my first post, so hopefully this is right.
I have just bought a Trio KA3500 Amplifier, but unfortunately, the No’s have worn off around the volume control. Being new to this renovation stuff, could anyone recommend where in the UK, I can buy some decal to replace them .
It is plain Black Numbering and I would need an odd line or Two replaced. Thanks, Colin.
novicerepairer is offline
Old 16th Aug 2020, 4:49 pm   #2
paulsherwin
paulsherwin's Avatar
Default Re: No’s worn off Trio Amp Facia
It is very, very difficult to get this right. I would be inclined to live with the wear, which is part of the amp's history after all.
paulsherwin is online now
Old 16th Aug 2020, 5:15 pm   #3
Bookman
Why not try your local sign manufacturing company. I have found that these companies possess a myriad or materials and software patterns that allow them to manufacture a vast range of products.
Bookman is offline
Old 20th Aug 2020, 8:28 pm   #4
Chris55000
Hi!
Would your budget run to buying this?
https://m.ebay.co.uk/itm/TRIO-KA-350...a-dee0a0fa9ea1
There's a switch broken off but it has a good lettered panel which you could lacquer to protect the lettering after you've cleaned it!
Lettering often wears off this sort of tackle due to repeated usage of the control concerned – the oil natural oils present on the skin seems to have a deleterious effect on silk screened lettering!
Chris Williams
Chris55000 is offline
Old 20th Aug 2020, 8:54 pm   #5
novicerepairer
Thanks everyone for your help and ideas, I think I will live with it like suggested, but if I find a really cheap faulty one, I like the idea of the facia swap as well, thanks all. Colin.
Old 25th Aug 2020, 9:31 am   #6
crackle
Letraset used to be the way to add numbers to control panels. Then a very clear artist varnish. But I have had problems with the varnish bubbling the letters in the past but they tended to settle down once the varnish had dried. You need to do very thin coats of varnish.
crackle is offline
